Question about Samsung HCL4715W 47" Rear Projection Television
HCL4715W Red timer light on nothing else.
I have an hcl4715w with the red timer light on. no picture or hv? can anyone help with this problem?
  • Paul Peterson Jul 09, 2008
    Can this board be component level repaired?
  • rswan13 Jul 09, 2008
    I have the same problem. Somehow fixed it about a year ago, having it again. Have turned it off, then on again. I don't even see a spot on my remote for setting a timer.
  • Samsung Master
  • 8,617 Answers
Thats a common problem for that chassis You will need the P54A sud deflection board. You can get a new one at the following link with free shipping. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jul 09, 2008
  • Sonny Berry
    Sonny Berry Jul 09, 2008
    Certainly as long as you have a good quality digital ohms meter and a ESR meter which will test capacitors in circuit and then you would need a service manual so you could test the various low voltage and operating power supplies. Once you found the correct circuit that isnt up to specs then you would need to trouble shoot that circuit. But you will definately need those three items to trouble shoot that Circuit board as all the misc. power supplies are on that one board.
Samsung three colors on screen, out of focus #hcl4715w
It is a convergence problem. The IC's (integrated circuits) or STK chips or the "guns". You have a red,and blue, IC's that provide all the colors. When the colors are out of convergence, you get ghosting or what looks like 3D pictures. I haven't been able to locate the part numbers for the IC's or STK chips but have located a convergence board. No luck determining if IC's are included (a phone call first to verify) but if they are, would make life much easier for you to install. Part # is BP95-00415H http://jr.partsearch.com/Part/Samsung/Samsung/BP9500415H/New.aspx?ModelMfgName=Samsung&ModelBrandName=Samsung&ModelNumber=HCL4715W
Typically, IC's cost around $10 or less. here is a link to a guy who provides pretty good instructions on replacing the IC's along with pictures.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Hope this answers your questions. Best of luck.
Greg
May 31, 2009 | Samsung HCL4715W 47" Rear Projection...
Red is outta focus on a samsung model#hcl4715w
replace the two convergence ICs and also check the 3.9 ohm resistors
Mar 15, 2009 | Samsung HCL4715W 47" Rear Projection...
HCl4715w
I would recomend getting the service manual for that set as that will have the info that you would need to troubleshoot so you have an idea on whats happening. You can get a service manual at the following link and they will assist you for free to help you diagnose whats going on.
Sep 14, 2008 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Red Tube needs replacement
you can get a red CRT (tube) for your samsung at the following link.If youre not sure which one you need leave them a email with your model number and what youre needing, they respond quickly.
Jul 15, 2008 | Samsung HCL4715W 47" Rear Projection...
Flashing red lines on Samsung hcl4715w rear projection
The convergence board wont correct the problem. You need to replace the two Convergence ICs on the sub board STK392-040 and you will be back to normal. See my response above. That site will help you get it back to normal.
Dec 21, 2007 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Rear projection CRT problem
your screen and focus controls need adjustment to acheive a good grey scale picture the adjustment are not on the crt neck boards.(focus block)
Aug 29, 2007 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Rear projection "Red" color is dim
screen adjustment,remove front bottom cove and find the focus block the screens are also on the same block,if your not sure don't try.
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W will not power on
At five years old, I doubt it will be worth replacing the power supply , a picture tube or two and possible the signal board. Cut your loses and get a new set.
Aug 25, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
123 people viewed this question
Henry  Thomas
Henry Thomas
