Question about Desa International Blower Glow Warm Wall Heater
THERMASTAT WENT OUT - Desa International Blower Glow Warm Wall Heater
    Genius:
  • 1,015 Answers
An excellent source for parts is www.best-price.com/DESA+PARTS. Hope this helps you. you will need model number and part no. if you have it. Good luck and have a good year. Thank you.
Posted on Jan 03, 2011
Our Robert Shaw thermostat 9520 just went blank. Do you have any ideas, nothing is working?
Try replacing the batteries.
Remove the cover by using a coin or screwdriver to prise it off. Insert the coin at the left side between the backing plate and the the cover, and twist.
Romove old batteries and insert new ones.
Mar 06, 2010 | Shaw Robert RS-9420 Thermostat
My scerity sys went off and I my car over heats I think it needs a new thermastat
maybe your security system monitors engine temp ... it doesnt have to be the thermastat thats bad .. it could be the radiator fan switch or relay bad .. you can tell which by the following.
1. if it overheats only when idling or in heavy traffic but does not overheat while on the road (moving) then your problem is more likely the radiator fan switch, relay or fan motor ..
2. if your car overheats all the time even while driving then it could be the thermostat ..
check belts, coolent level and radiator clogging ..
Feb 19, 2010 | 2001 Pontiac Aztek
Cooling system
these are somethings that maybe causing it to over heat (1) not enough cooling in it.(2) water pump drivebelt (3) Radiator core blocked (4) Bad thermostat (5) fan blades broken or cracked (6)Radiator cap need to be replace (7) Ignition timing incorrect if all fails stop by your local library and get your hands on a Haynes auto repair Manual for your car wish you the best of luck Michigan Man
Dec 09, 2009 | 1995 Mercury Cougar
No Power to Duo-Term Thermastat
Can you give me model #'s of thermostat & AC unit, as well as upper unit? Number of or at least a description of thermostat, and numbers for ceiling assy should be visible when filter taken off, as well as # for upper unit should be tagged on bottom of unit on roof.
Jul 17, 2009 | Heating & Cooling
1995 toyota 4runner gets hot with new thermastat gasket
the thermostat should be closed when you take it out, therefore the thermostat is bad. It does not closed.
May 22, 2009 | 1995 Toyota 4Runner
Overheating
Posible thermastat sticking closed. If thermastat doesn't open heated water is trapped in the engine causing it to run hot and not allowing hot water to travle to the heater core when called for.
Nov 20, 2008 | 2002 Mini Cooper
Desa International Blower Glow Warm Wall Heater Logo
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
