I need to change fuser rollers on my c500 - Office Equipment & Supplies
  • 147 Answers
Http://www.provantage.com/lexmark-c500x28g~7LEXA1HU.htm
This is a complete part the above link shows what it looks like. Remove in one piece and replace it.
Posted on Jan 03, 2011
Toner Not Sticking Well
There is a long bulb placed in the centre of the fuser roller below the pressure roller.
Check the halogen bulb INSIDE the fuser roller. Does it glow ?
Ensure the Voltage of the bulb matches your country.
Laserjet 5000 5100 fuser TPW LJ 5000 Assembly Diagram 810
Mar 26, 2016 | HP LaserJet 5000 Printer
What is the utility key when trying to reset a fuser abnormality code on my konica minolta pro c500
Sir,
TO reset that code on C500 is not done with the utility button.
1. First power off the machine.
2. Hold down the 2 and 5 button and power on the machine.
3. Wait for screen then select Soft switch settings.
4. See a new screen, in the first box on your left put a 3
5 in the second box put a 1
6. In the third box you are going to change the 1 to a 0.
Exit. power off the machine. Wait ten seconds power on. If the code comes back have a technician look at the machine do NOT RESET again you are resetting the codes for the Fusing unit the Hot part could CATCH on FIRE!!!!!!!! or do more damage to circuit boards.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 11, 2014 | Konica Minolta bizhub Office Equipment &...
The paper is crumpled in the lower part of the paper.
Maybe you have problems with the upper fuser roller, open the back door and try to see the upper fuser roller and lower pressure roller if you see any wrinkles or damage in any of the rollers that's is the problem, you can replace them just the upper fuser roller and the lower pressure roller but it will need advanced skills, the other option is change all fuser assembly but at higher price
Nov 26, 2013 | Brother HL-5250dnt Laser Printer
Fuser upper roller problem
Apparently you just need the pressure roller, if noisy, you can change the bearing.
Good luck ...
Apr 24, 2012 | Canon imageRUNNER 8500 Copier
Hp 2420 leaves vertical line across the page. we changed the fuser 7 months ago
It sounds like you may need to change it again. These printers use a Teflon coated heat roller in the fuser. If you print envelopes that will scar the heat rolller, this can also happen if there is a piece of paper jammed in the fuser assembly and it scraped the fuser roller. Open the back of the printer and look at the roller in the fuser. I would bet that you see the roller is damaged. Here is a link to a post about the Laserjet 2100 printer with the same issue. It has pictures of the roller and what to look for, the fuser is different but the principle is the same.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 20, 2011 | HP LaserJet 2420dn Printer
Reset ep 1031 plis
Is the code c500? if so power off then on if returns means that the fuser the hot part is dead. have to replace the upper fuser roller and lamp. service technician required unless you bye the parts and replace with service manual.
Apr 24, 2010 | Minolta EP1031/1031F CS/PRO Copier
Brother MFC 7420. New Brother Toner, New Drum, cleaned feed and separator rollers, changed paper, still jamming. Paper stuck around brown fuser roller. What can I do next?
Check whether the fuser rollers are free turning. If the paper is stopped at the ejection roller, the ejection roller needs to be replaced.
Dec 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
I need to know how to replace...
The transfer belt cleanning blade is under the transfer belt.Remove 2 screw and change it.The bias transfer roller is mounted in two bushings,remove the bushings and 2 springs.The fuser unit : upper fuser roller,lower fuser roller and the cleaning rollers.
Aug 25, 2009 | Office Equipment & Supplies
Printouts have type ghosting
Change the fuser unit if you have to hand. The problem is likely caused by a lack of pressure from the pressure roller. Also check the transfer roller for a similar ghost image.
Sep 14, 2008 | Samsung CLP-510 Laser Printer
48 people viewed this question
k24674
jasbo
jasbo
