Question about Kenmore 42926
Have Kenmore model 110 82872100 washing machine. Was leaking water when medium or full load was used. Took apart and replaced 383727 gasket at the bottom of tubs. Put everything back together, and the machine works ok except when it is time for the spin cycle. The machine rattles and makes load noises like there is a pair of tennis shoes inside. What did we do wrong or what did we miss? Any help appreciated. Thank you.
  • 11 Answers
SOURCE: Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Posted on May 20, 2007
SOURCE: washing machine broken, kenmore model 110.92274100
I have the same problem as posted on mar 30, 08. seems like the clutch will not engage, the motor turns but the drum won't spin (wash. move). would you give us follow -up instructions for clutch & gear case on how to replace it.
Posted on Jul 27, 2008
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
vanni7
  • 163 Answers
SOURCE: Washer making noise during the spin cycle
Hi!!! it looks like your motor coupler is failing..Good luck..
Posted on Jan 04, 2009
WRMtech
  • 70 Answers
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Posted on Feb 24, 2009
I have a Kenmore top load washing machine and it is dripping water inside. Do i need to replace a valve or a gasket?
Until you find out why it is dripping turn off the water behind the washer. Then I would go and search online typing in the browser search "Kenmore top load washing machine model no _____ leaking - what is causing this?" and hit enter. You will get lots of leads. I did a quick search just on Kenmore top load washer leaking and found this video.
Hope it helps.
Tami
Mar 03, 2015 | Kenmore Washing Machines
Water leaks with larger louds on kenmore front load eco
Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Feb 01, 2013 | Kenmore Washing Machines
Door gasket leaking
My GE washer model wcvh6400j0ww was leaking too. The repair person thought the same thing the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 20, 2010 | GE WBVH6240F Front Load Washer
Smell from water remaining in grey seal
My GE washer model wcvh6400j0ww was leaking. May be standing water under your machine. The repair person thought the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 13, 2010 | GE Energy Star WCVH6260F Front Load Washer
Kenmore model is leaking on full load but not
Leak maybe coming from the tub (higher level water) need to take the shell off the machine to see where exactly it is leaking from
Mar 25, 2010 | Washing Machines
I have a Kenmore heavy duty washing machine model C110. When the machine has a full load and a high water level, it leaks, but when the level is lower ( small load ) it is ok. Also under the machine on the...
The water leak is from the white tub cover on top of the tub. The seal needs replaced.
The oil is from the transmission.
I honestly would replace the washer.
Jan 12, 2010 | Kenmore 24032\24036 Top Load Washer
Maytag A806 washing machine leaking from the center,under the tub
The tub seal is bad.
I had the same issue on another model.
You can attempt to repair this yourself. I suggest that you do a search on Youtube to see if this is a job you want to take on. It took me 2 hours to change mine. The seal kit and tools are sold online.
Good luck.
Sep 27, 2017 | Maytag Washing Machines
My front loading Kenmore H2 has a torn gasket.
You will have to take the door apart to get the gasket mounted properly. Although not required, a second pair of hands really helps.
Mar 19, 2009 | Kenmore HE2 Plus Front Load Washer
My top load whirpool washing machine leaks during spin cycle.
it only does it on the small load? does the water drain out before it goes into spin?
Nov 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
55 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
