Question about Garden
I purchased an unboxed, without manual, Husky H1506F air compressor from Home Depot and it has stopped working after very limited use. Was I supposed to be oiling it or something? I did smell something, perhaps a burning, beforehand. Is this repairable? Is there a manual online?
  • 1,514 Answers
The manual is available from http://powertool.manualsonline.com/mdownloads/053542d2-5ea4-4ff0-9302-72ea88716453.pdf
Unless you tried to operate a tool that the compressor wasn't powerful enough for I don't think it would have been possible to do something wrong with it. Have a look at the manual and if you think you did everything right you might be entitled to get a refund or replacement from the seller.
Posted on Jan 03, 2011
Testimonial: "I appreciate you finding the manual online. I did an extensive unsuccessful search myself before submitting question. I appreciate this very much! "
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    Air compressor cannot spin up with pressure in tank sometimes
    There is an unloader valve and a check valve on the discharge side of the pump. The check valve is not holding and the unloader is not dumping the pressure so the compressor cannot start. Since it is new, you may want to take it back. If not you are going to be replacing parts.
    Mar 10, 2014 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    Need Manual for Husky Model 41214 Air Compressor
    You can get the manual for model 41214 from my dropbox area:
    http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
    BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
    http://db.tt/vQycqXIW
    Thanks,K
    Dec 20, 2009 | Air Tools & Compressors
    I need the manual for my Husky 1/2" air impact wrench
    Home Depot carries Husky products, Id start with them...
    Nov 30, 2009 | Impact Husky® 1/2" Wrench
    I have 3 compressors, all of them refuse to stop compressing until i manually shut them down,husky 26 gallon upright 5 yrs old, porter cable pancake 2 yrs old. and a master elite? came from home depot as...
    the regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
    Nov 13, 2009 | Porter Cable Air Tools & Compressors
    Portable oiless compressor wont pressurize
    If there is pressure at the pump, either:
    1) The tank check valve isn't opening (it's located where the line from the head enters the tank - usually extends into the tank, and the the pressure switch unloader line comes off of it as well)
    2) The pressure switch unloader is bleeding off the air. This is a small valve on the side of the pressure switch. It should close when the compressor is running and open when the compressor shuts off to bleed off head pressure.
    Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
    Husky air compressor/1.5 hp
    Compressors pull a lot of juice that is why they come with a large power cord. If you use a small extension cord with it it will easily pop a breaker. So first check all your breakers. Second thing is check your manual to see if you have a reset switch on you compressor, as most do. It should be a small, red switch (rocker or push button type), located between the pump motor and compressor switch. The third is a long shot, check to see if the bleeder valve is functioning correctly. It will be the small copper tube running from the pump to the switch. Just make sure the small lever is free to move.
    If this fails to resolve the problem then it is probably the main switch itself. That is a warranty issue. If it's out of warranty then your going to have to either repair or replace the switch yourself. Please feel free to ask for help if you need it in latter case.
    Jun 07, 2009 | Air Tools & Compressors
    Garden Logo
    538 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
