Question about HP Color LaserJet 2600n Printer
How do we stop printed documents from being smudgy with double/triple print all over the page?
  • ljohnston8 Jan 03, 2011
    How do we fix a fuser on the printer?
  • 147 Answers
There are 2 issues here
1 if regular paper (20lb) and you see the same image 2 or 3 times repeated down the page, you have a bad FUSER. it is a consumable. (this is called "ghosting")
2 if you are using paper other than 20lb you need to set the paper type to a heavier weight. This will increase the heat. I think it is a fuser problem unless...
if one colour is doing it, then change that colour cartridge.
Feel free to PM me if you have more questions.
Posted on Jan 03, 2011
  •  Steve
    Steve Jan 03, 2011
    Replacement only, they wear out over time with the heat and paper friction.
    here is a link to buy a new one. http://www.partsnow.com/Parts/Productpag...
    Remanufactured fusers will not last as long.
Double sided printing
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 14, 2012 | HP Photosmart Plus All In One Printer b210
How to duplex print with 895cxi
This model printer does not have a duplex unit and cannot print double sided documents automatically.
Jul 08, 2012 | HP DeskJet 895cxi InkJet Printer
How to print two sides
Jan 14, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
How cancel the print job in cannon lbp 2900 printer
Hi and welcome to fixya,
Go to control panel > Devices and Printers
double click your printer, you'll be able to see the queue...Right click on the document and select Cancel printing.
You can alternately push the power button to immediately stop the current page being printed. You will receive an error message but click cancel and proceed normally.
Hope this helps
Feb 03, 2011 | Canon LASER SHOT LBP-2900 Printer
Not fully printing any document
Print a test page and perform head clean if necessary.
Oct 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
New ink and it only prints in strips
Try to do an ink cartridge cleaning
Open the print page
Click on Preferance
Click on Color
Click on Printer Services
Select your cleaning options
Mar 13, 2009 | HP DeskJet F4180 Inkjet Color All-In-One...
Repeating wide smudgy horizintal line across my printed pages
I had the same problem, replaced the PCR in the cartridge, the small black drum that pre charges the drum and erase the old image.
After that print was all back ok.
Regards
Dec 11, 2008 | HP Q2613A OEM Genuine Black Laser Toner...
In this printer u dont have duplex print mode,u can use only manully.
Oct 10, 2008 | Canon PIXMA iP3500 Printer
Deskjet 3520. I mistakenly clicked on print a 200 page document when I only wanted 7 pages. I cannot stop it from printing. Tried cancel and even unpluging it and each time I reconnect, it continues to...
Click on control panel, then double click printers and faxes, then double click the printer you are using, a panel will appear, and you click on the document name you have entered, then click on document, then cancel and click yes when asked if you want to cancel the print job. It will take it a little while but it will clear the job you have entered.
Aug 22, 2008 | HP Office Equipment & Supplies
HP Color LaserJet 2600n Printer Logo
105 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
