My pc window vista says vongo stopped working a problem caused the program to stop working correctly how do i fix this problem i have no money
  • 326 Answers
There is a problem with vongo that only happens once you have tryed to use windows media player. if you attempt to set up media player vongo will no longer work in media center. this is an issue that vongo must solve and the more calls they receive on this matter the sooner they'll work on it.
Posted on Jul 09, 2008
When enter my log 0n I receive this message: Skype has stopped working. A problem caused the program to stop working correctly. Window will close the program and.................. This happened...
Skype changed in the update. You probably have yours set to run in compatibility mode for Vista Service Pack 2. This crashes the program now. Only fix I've found is turning compatibility mode off, which sucks cause it won't minimize to tray. But it runs at least.
May 16, 2011 | Skype IM
''Advanced Vista Optimizer 2009 has stopped working''
just get rid of that programe in your computer, surely it will not optimize because it incures problemes for your windows.
obviously it does not pass the windows specifications.
Sep 22, 2009 | Computers & Internet
A problem caused theprogram to stop working correctly. Windows wi
Your problem is a little hard to say. Have there been any power outtages or has you computer been powered-off rather than the regular shut-down procedure. Windows registry and programs can be thus corrupted.
Also computer viruses can disrupt programs so please run for example
Mcafee's free online anti-virus to rule-out a virus problem.
http://us.mcafee.com/root/campaign.asp?cid=45694
Even if you have an anti-virus installed, it needs to be running the latest virus definitions.
You could also try in programs accesories system tools to select "system restore" and bring back your computer to a date where you understand the problem was not happening. (Try this one last)
Jul 11, 2009 | Computers & Internet
''WINDOWS DVD MAKER HAS STOPPED WORKING''
The optimal thing to do is remove the software program and re install it. Just as a word of warning if you don't know what services should be starting up with windows you should not disable any. Its fine to disable programs from the start up options, but as a rule of thumb stay away from the services.
Chances are this is a software program problem not computer.
If it still does not work, please post your question more thoroughly. Good Luck.
Jan 15, 2009 | E-Machines Computers & Internet
My laptop is not working right, it is extremely slow and something called Vongo keeps trying to install but won't and it won't do anything
Uninstall Vongo:
1. Restart the Notebook and keep Tapping F8.
2. Select Safe Mode and press Enter
3. Click on Start, select Run, type "msconfig" press Enter.
4. Click on Startup tab and uncheck the check box besides "isuspm"
5. Click OK and restart the system for the new settings to take effect.
Kate: Note: After you restart the machine you may receive a dialogue box stating 'System is running using Selective Startup', Check 'Don't show this message or launch the system configuration utility when Windows Starts' and click OK.
Kate: Now, restart the Notebook again and go into Safe Mode by tapping F8. Click on Start -> Control Panel -> Add Remove Programs.
Locate the Vongo Software and click on Remove to uninstall it.
If this does not resolve the issue, you may have to manually delete the files:
1. Double click on My Computer
2. Double click on C Drive
3. Double click on Program Files
4. Select the Vongo Software folder and press Delete.
5. Close the Window
6. Right click on Recycle Bin folder and select Empty Recycle Bin
This will remove the Software.
Now, run the Windows Installation Cleanup Utility, this will remove the registry entries for the Software.
You can download the Utility from the given below link: http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
(Note: Do not click on the link. Copy and paste the complete link in the address bar of the Internet Explorer.)
The Windows Installer CleanUp Utility does:
• Provide a dialog box where you can select one or more programs that were installed by Windows Installer. You select the programs on the Installed Products list in the Windows Installer CleanUp dialog box. After you make this selection, the utility removes only the Windows Installer configuration information that is related to those programs.
• Remove the files and registry settings that make up the Windows Installer configuration information for programs that you select.
Hope this resolves the problem with Vongo. Would appreciate if you rate it.
Thanks,
ArnWuLF
Nov 30, 2008 | HP Computers & Internet
Software problem
restore your laptop last known, unistalled the sync software from control panel programe and features, and reinstalled it or repair it
Oct 16, 2008 | Dell Inspiron 1501 Notebook
Problem with Compaq Fortran & Vista
I found the solution fortunately:
It's enough to do a right click on the bottom: "Developer Studio" instead of double click, and select: "Run as Administrator" , then select: "Allow" and so on..
Try it, it works!
Aug 06, 2008 | Compaq Visual Fortran Professional Edition...
Dvd
Are you wanting to make a virtual copy of a DVD for usage later, or watch a movie by downloading it off the internet? If you buy software designed to circumvent the copy-protection built into today's DVD movies, you're going to spend a lot of money doing so, and filmmakers always change / update their copy-protection procedures and the software won't be able to keep up. One way to watch movies on your PC (that I personally use) is VONGO, which is video-on-the-go abbreviated. Vongo works well, and is relatively inexpensive.
http://www.vongo.com/
There may be other services that do the same (or similar) thing(s) but I know Vongo is a good service, and no, I don't get paid anything to endorse them. It is easy to use and many movies are free.
Dec 26, 2007 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
David Payne
David Payne
