Question about Maytag Washing Machines
Maytag A206 timer going through the cycles rinse clicks in the machine begins to spin slowly then shuts down
  • 1294 Answers
SOURCE: Shuts itself off before each Rinse or spin cycle.
Maybe your spin or rinse cycle button is in the off mode. Refer to your user's manual, if you hv one.
Posted on Apr 11, 2007
Scott Ellin
  • 558 Answers
SOURCE: Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Posted on Sep 26, 2008
jumptrout51
  • 3361 Answers
SOURCE: maytag top load washer won't pump water out=intermittent problem
You have a belt driven pump on this machine.
Maytag redesigned the lid switch for this machine because of this problem.
Try a new lid switch first.
It is possible that the problem could originate from the timer. Which would mean a new timer.
I believe the lid switch will correct your problem.
Posted on Mar 10, 2009
  • 6 Answers
SOURCE: Machine won't rinse or spin properly..also stinks!
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on May 08, 2009
SOURCE: Maytag Atlantis MAV6200AWW; Washer goes through
Maytag Atlantis washer goes thruout washing cycle,but dosen't simse or spin....
Posted on Jun 12, 2009
Washer stops before rinse cycle
Check the water level sensor.
Nov 25, 2013 | Maytag Washing Machines
My Maytag top load, looks like PAV2300 but not sure, will not rinse. The water drizzles a bit during the cycle and I hear the timer but the machine does not rinse. I cannot force it into rinse. I have to...
Hi and welcome to FixYa. I am Kelly
There is a water level pressure switch inside the top panel that has 3 wires on it and a vacuum line. That pressure switch controls the water inlet valve functions via the timer.
If by chance the pressure sensing line is getting hydraulically locked with water due to some form of obstruction it can cause the symptom you describe.
This pressure switch also controls the start of the spin once the water level has dropped (prevents the wash tub from being a water brake and damaging the motor clutch)
If the water level pressure switch is working normally then the only thing left is the timer.
You can do your own testing of the water level presure switch with an external vacuum hose (3 feet in length) connected in place of the machine hose. (DO NOT drop the machine hose when you disconnect it!)
1. place timer on wash and start filling. LID CLOSED
a. Force air orally into the external line
1) Result fill stops agitation begins
2. place timer in spin LID CLOSED and force air into external line until the pressure switch clicks.
a. START SPIN CYCLE NOW and listen for water pump out
b. release pressure on external air line
1) result tub starts spinning
If it passes the above tests your looking at a timer problem causing your no rinse situation.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Maytag PAV2300 Top Load Washer
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Maytag SAV5910aww will not always drain. Fills and agitates fine but will go through entire cycle without draining. Will sometimes give end of cycle buzz sometimes not. If I am in the room and lift the lid...
"I have found spinning the timer back to begining of rinse cycle first helps". The timer only rotates clockwise; counterclockwise rotation can destroy it.
May 18, 2017 | Maytag SAV5910 Top Load Washer
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Jul 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Dec 24, 2006 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
