Question about Canon PIXMA MP160 All-In-One InkJet Printer
What kind of ink cartdiges does it take - Canon PIXMA MP160 All-In-One InkJet Printer
  • 613 Answers
Canon PG-40 for black and Cl-41 for Color
Posted on Jan 03, 2011
I have replaced the black in ink in my canon MP470 with a refilled ink cartdige but keep getting a U162 (the ink may have run out, please replace) error message. hoe do i get rid of this meesgae and get...
Pressing the OK button will allow you to continue to print. Since the cartridge has been refilled, the printer ink level monitoring function will not work
Mar 27, 2011 | Canon PIXMA MP470 All-in-One Printer
I have just replaced my black ink cartridge and it shows allingment failed and my colour cartdige is low
Hi Paul,
I too have a C4180, and am getting Carriage Jam messages. I believe my problem to not be paper jams, but instead glob of ink that have collected under the cleaning mechanism on the right side of the printer. If you look inside you may find the same problem. There are (felt-type) absorbers and mine are soaked with ink, and the also some globs. There is a plastic tray that moves back and forth to clean the ink cartridges and it is no longer moving freely due to the ink.
I am trying to find a service manual to be able to disassemble and clean up properly the dripped ink. In the meantime I have used qtips, paper towwels and alcohol to try to remove the bulk of it.
Try this and let me know if it works for you.
Mike
Jan 25, 2011 | HP PhotoSmart C4180 All-in-One Color...
I have a lexmark all in one X7350 and it appears as if the color ink cartdige is full, but I cannot print any images in color. Any suggestions?
remove the ink cartridges and clean the nozzles out with rubbing alcohol. when cartridges and empty and not replaced with 24 hours the nozzles will get plugged up the nozzles of course are part of the printer were the ink flows through as received from the ink cartridge
Jan 14, 2011 | Lexmark Office Equipment & Supplies
It said removed and check cartridse
turn of the printer and remove the cartidge... try to check if the cartidge has some smears or the slot where the cartidge gets placed check for ink smears .... the dotted bronze part on the cartdige or the printer act as the connector between them try to rub them gently ... turn on the printer and place them back in once it ask you to do .... i guess it will resolve your problem
Apr 12, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Cru fuse error on samsung scx 4521f
i changed fuse 4521F , but : (cru fuse error) ???
Feb 12, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Put in new ink cartridge and get error black and color cartridges need replacing
"New" refilled cartdiges? Or new from the manufacturer? Some printers have chips in the cartridges that "know" when they ran out of ink, and they have to be reset. If the refiller didn't reset the chip, it still "thinks" that the cartridge is empty.
If they're new cartridges, bought from the same place at the same time, I'd suspect bad cartridges.
Jul 22, 2009 | Office Equipment & Supplies
How do I change the ink cartridges on a canon mp210
tget the manual free copy this site and paste it in your ADDRESS BAR and hit ENTER.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#BrochuresAndManuals
(14) FINE Cartridge Holder
Install the FINE Cartridges here.
The Black FINE Cartridge should be installed into the left slot (ug_before_printing6.jpg) and the Color FINE Cartridge should be into the right slot (ug_before_printing7.jpg).
(15) FINE Cartridges (Ink Cartridges)
A replaceable cartridge that is Print Head and ink tank integrated.
i_note.gif Note
For information on how to install the FINE Cartridges, refer to your setup sheet.
(16) Scanning Unit (Printer Cover)
Scans original documents. Open it when replacing the FINE Cartridges or removing jammed paper remaining inside the machine.
This is in the first part of the Manual.
Hope this is of some help. Bud
Jun 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Newly replaced black ink cartridge still shows up ink supply empt
have you used the printer properties menu to recharge the ink? Just right click on the printer icon, choose properties, click on the Maintenance tab and click on the ink cartridge replacement. You have already replaced the cartridge so just click through to the end. The last thing it does is recharge it. I think this must be where it decides it has been replaced and is full.
Dec 29, 2008 | Epson Stylus C86 InkJet Printer
Printer will not print even though the cartdige is new
The ink heads are clogged with dried ink.
Follow these steps:
1) Begin saving money for a new printer.
2) Lift the scanner to get at the ink. Remove the cartridges.
Take cotton swabs and alcohol and clean all the ink off of the top of the heads (located in back.  they're the pointy things) until you can see the holes.  THE CRUCIAL STEP: Insert something-small enough to fit in the holes-all the way through every hole in every head. This should clean out the dried ink and allow your printer to continue to work.
3) If step two doesn't work, I really hope you did step one.
Don't buy an Epson.  They also have this other feature which prevents printing when one cartridge is empty.  Even a color cartridge.  I recommend a Canon, if you like name brands, or an HP.
Jul 05, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
