Question about Kenmore Dryers
My Kenmore gas dryer mod 110.77522600 burner light when I first turn it on. After 4 mins. or so, it goes out. It will try to relight several time (igniter glows) but it never does.
    President:
  • 1,430 Answers
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils. If you need further help try this link for troubleshooting a gas dryer
Posted on Jan 03, 2011
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
Burner on dryer comes on then shuts off and will not relight
This is only a guess based on experience: the unit may have a thermal sensor for a pilot light much like old gas wall heaters, it if bad will not allow the gas on or turn it off if pilot light goes out.
If its there it should be right at the pilot light.
Dec 21, 2012 | LG Dryers
I have a gas dryer that will light initially,then goes out,attempts to relight several times ,and never does.I took it all apart,cleaned burner.Vent system is clear.
change the thermocouple ( the small tube like object that sits directly in the pilot flame ) , , be very gentle with them as the can easily be destroyed with over tightening , bet still get a gas engineer to do it
Oct 21, 2009 | Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Have-kenmor-80-series-dryer-about-5-yrs-old-losess-flam-about-6-min-into-cycle attemps to relight no flam.
replace coil kit no 279834.coils will be found on top of burner, unplug wires, 2 screws remove bracket,easy fix part~ $20 .Hope this helps ,please rate my solution :)
420.. 20 min fix .hope thuis
Jun 27, 2009 | Kenmore 73952 Gas Dryer
My kenmore dryer will start and run when cold after it heats up the flame (gas dryer)goes out then after 3 or 4 mins. i can see the igniter light but will not start a flame after 5 or 6 seconds the igniter...
gas valve coulkd be bad if not opening after a certain period of time the ignitor will turn off and attempt a few times more,does it have a soilenoid valve also open and clean any carbon that might be built up over yrs
Jun 21, 2009 | Dryers
Dryer runs. No heat
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer won't dry
kbaker926:
This is a purchased product manufactured by another manufacturer for Sear.
It sounds as if have a flame sensor or a thermostat opening turning power off to the burner thus flame goes out.
If you are able to to catch the dryer just as it shuts off you would be able to do some ohms readings to find out what components have opened in the curcuit.
((((This is only if you are able to properly use and read a Volt-Ohm meter))))
These checks should only be done with the Electrical supply turned OFF and at least one wire disconnected from the component being tested
Woodychoppers
Oct 31, 2008 | Kenmore 75944 Gas Dryer
Kenmore gas dryer
lots of people point the finger at the dryer when they have a problem you could have bad thermal cutoffs on the back of the flame tube BUT is your washer spinning properly to remove the majorityof water from the clothes
Jan 02, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
99 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
