Question about Bernina Virtuosa 160
The bernina virtuosa has a v 2.0 windows 95/98 cps cd for programing stitches to the machine, now when loading the program an error states language info file open failed, then it closes. Is there a solution for this so I can download to computer?
  • 3 Answers
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Posted on May 22, 2008
RickE1
  • 202 Answers
SOURCE: Timing for Bernina Virtuosa 153
Timing these machines gets pretty involved such as in just removing the covers. You need a grounding ******** your wrist as the cables all need to be unplugged and you don't want to send a static charge from yourself to the circuit boards. They are expensive. Then you need special sized metal pins to pin several pinning points so the needle, hook, stepping motors and feed dogs all co-ordinate with each other. Also several places need certain guages to set less than .1 millimeter size distances between different places to avoid other problems. You also need several sized torx screwdrivers and the knowledge to adjust the upper and lower tensions. The upper tension alone has at least 3 or four places that need to be in the correct position.
All of the above has to be done in a certain order also.
Its complicated enough. If someone is going to walk you through this over the phone expect it to be complicated. Even if you had a copy of the manual (which could be a copywrite infringment on newer machines) you can expect it to be difficult.
My advice is to leave it to the professionals to have it done right.
Posted on Jun 20, 2008
  • 13 Answers
SOURCE: old bernina 830 stitching problem: tight
Sounds like you need to adjust the tension. Probably a good idea to oil this older machine before you adjust. Also look for and clean out any lint or debris in bobbin case and around foot area.
Posted on Aug 29, 2009
  • 14 Answers
SOURCE: looking for the manual for
just visit www.janomestuff.com
Posted on Sep 17, 2009
SOURCE: I have a Bernina Virtuosa 155 and use it daily. Without
In checking I can either adjust the tenion screw and if that does not work, purchase a new bobbin case.
Posted on Oct 28, 2009
Can a Bernina Virtuosa 153 still download stitches into its CPS system with Windows 10?
The Virtuoso was pre-Windows 10, so a Windows 10 system will probably have some issues. You might want to contact Bernina. They can tell you if your machine can be upgraded to Win10.
Jun 10, 2017 | Bernina Sewing Machines
Bernina virtuosa 153 doesnot maintain stitch lengh selected and throws a zigzag in with a buttonhole stitch.
any machine I ever used sews button holes with zigzag and very short ones at that .
Jan 05, 2017 | Bernina Sewing Machines
I have a bernina virtuosa 150. how do you change stitches with the cps system?
try contacting bernina customer service and ask them how to
change the stitches
Feb 06, 2013 | Bernina Virtuosa 150
I have a Bernina Virtuosa 153 sewing machine that is skipping stitches while trying to shorten a pair of jeans. I changed the needle to a 100/16 and am using all purpose thread.
You may need to increase the foot pressure to cope with the heavy denim material. Look carefully at the material as the machine tries to stitch ... if the foot is not keeping the material firmly on the stitch plate, it might be riding up on the needle (denim tends to be rather 'grippy') which will prevent the thread loop being formed correctly below the stitch-plate and therefore not getting picked-up by the CB hook. Changing to a bigger diameter needle might actually make the situation worse in this case ... go back to an 80 and try again.
Sep 17, 2011 | Bernina Virtuosa 150
I can't find my Virtusoa 150 user manual. Need basic stitch setup
If you will send me your e-mail address privately, I will scan some pages from my manual and e-mail them to you.
Kathy
soot@iowatelecom.net
Jul 25, 2010 | Bernina Virtuosa 150
Bernina Virtuosa 153 Quilter's Edition sewing machine jams
Bernina Virtuosa 150 pressure foot does not go down quite all the way. The stitches don't go straight and are not even. PrewettOE
Apr 07, 2009 | Bernina Sewing Machines
Machine not stitching
In my town, when you buy a new Bernina, you get a free series of classes to learn how to use it. Call your store and see if they have a "Get to know your Bernina" class for your machine.
Jan 13, 2009 | Bernina Virtuosa 160
Programmed stitches on the 160
As a Bernina tech I can tell you to try adjusting the stitch balance with the small knob on the side + or -. Just in little increments until they start to look right. Maybe this has gotten turned too far off. If this doesn't help (50/50), worst case scenario most likely the small gear has been jarred loose or has skipped a tooth to the stepping motor which means a tech will have to reset this and balance it from the inside. There are also steps to take in the service program but again this would be a job for a tech. I suggest you get the whole clean, oil and adjust as this would be included in that.
Apr 12, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
98 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
