Question about Gator Cases Gator GWECLASS Hardshell Classical Wood Guitar Case
When opened, case will not stay open. Band between top portion and bottom at bottom appears to be twisted or incorrectly glued.
  • 94 Answers
YOU CAN TRY TO RE GLUE THE BAND. JUST MAKE SURE THE TENSION ON THE BAND IS FAIRLY FIRM. THIS WILL HELP IT STAY OPEN BETTER.
Posted on Jan 03, 2011
Yamaha psr700 speaker cover removal
Assuming this is a PSR-S700 then you need to undo all the screws under the keyboard and open up so you can see inside under the speaker grill. You will see the grill has tabs that poke through the casing and these are then twisted to keep it in place. Straighten these, push tab through casing going from side to side and then the grill will eventually work free. You do not want to do this too much as the tabs will eventually break with wear.
Jun 18, 2016 | Yamaha PSR-S500 Digital Keyboard
I can't get the back open to replace the batteries.
Hi Esther:
Try sliding it from top to bottom while you are pressing it.
Oct 20, 2015 | Seiko Quartz Metronome W/easy-op Tempo...
Boss e-band js8
Check earth connection and check for static buildup around twist and slide controls by moving them briskly a few times. If humming stops or lessens for a while then gradually builds up again, it needs a service.
Apr 05, 2014 | Roland Music
Peavey xr1200 blows 8A fuse after about one second. Old mixer, seldom moved, has worked fine for years
If it blows a fuse when powered on, it has a dead short somewhere. Old units do this when the capacitors (filters) get old and dry out. These create dead short circuits. I recommend going through the unit and change out the bad ones. They can usually be spotted easily. They look like little cans glued on the board with an "X" on top. They are usually blue, gray, or black. The X on top is a weak spot allowing the top to open or pop up when they go bad.
Mar 22, 2014 | Music
Need to find how to open a NXD200 from numark... cause i got a problem with 1 button
It's just the screws in the bottom that hold the top and bottom shells together Possibly some on the sides.
Sep 21, 2011 | Numark Industries Numark NDX200 Tabletop...
I Have a yamaha dx7 fd with 2 broken keys, they stay down can be lifted manually and make a sound . can I fix this myself
Open the unit CAREFULLY to avoid damaging cables between top and bottom. Inspect the defective keys. It may either be a broken part on the key OR the silicone rubber key contact carriers that can act as springs. Get repair parts from Yamaha America in California. Find number online and call the "parts department"
Sep 27, 2010 | Yamaha Music
One of the keys catches/stops about 1/2 way down. It can be pushed all the way down with effort. Sound occurs when it is pushed all the way down, but it is muted somewhat
Open the unit being careful of the cables between top and bottom of the unit.
The problem should be fairly obvious. The muted is because teh velocity sensing contacts are not making in the usual time so it acts like you are hitting the keys very slowly.
It will either be something jamming the key or a broken part OR the silicone rubber carrying the conductive pills has broken down.
Sep 26, 2010 | Casio Privia Keyboard Case
I read the solution for removing a key on a yamaha p-80 electronic piano...and is a big help...but was wondering if opening the piano is difficult....i have a bad white key...i live in mexico with no help...
There are a myriad of screws to remove around the edges and maybe a few near the middle of the bottom of the unit. When lifting the top off, be extremely careful of the cables between the top and bottom... have a large work area, padded, and have a helper to hold stuff when lifting top off. Do NOT force anything... feel if something is still connected and preventing the top from comming off. The keys should stay with the base of the unit.
Aug 22, 2010 | Yamaha Music
Output is low and distorted
The way you troubleshoot this is to divide and conquer. Run KNOWN clean signal into the "Power AMP IN" jack (note that it is a balanced TRS type input).
Verify the power amp downstream is clean. If not, then confine testing to power amp portion.
I would also check that the voltage across R66 is near correct IFpower amp portion is at fault.
I AM suspicious that the voltages on the scjhematic are AC peak to peak values rather than DC...
I think things in ovals are AC and rectangles are DC.
Aug 29, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Gator Cases Gator GWECLASS Hardshell Classical Wood Guitar Case Logo
61 people viewed this question
Top Gator Cases Music Experts
Michial Gueffroy
Are you a Gator Cases Music Expert? Answer questions, earn points and help others
