Question about Radio Communications
I have a President HR 2510 with chip switch, worked fine left it in the garage for a year now it does not respond to controls. Is it repairable or should I seal it for parts and buy what? Money is an issue I am disabled and would like to get back into radio. I had a HAM LIC but let it lapse when I worked 16 hrs a day until my body broke. Know no money just time.
  • ern1900 Jan 18, 2011
    No as you can see.
  • 8,197 Answers
Sorry we can not help you with your problem.
Posted on Jan 15, 2011
    Problem Solver:
  • 26 Answers
I have same problem. I know the post is old but... if it powers on and you can see display just keep on and start to use ch up&dn over n over after a bit contact will start. Make shure the lock is off as well
Posted on Aug 15, 2012
D104m6 wire it to 2510 cb
Pretty sure it can be done but you need a wiring diagram for the radio pinout and the mic. Best leave it to a CB service shop.
Oct 11, 2014 | Uniden 5 Pin Cb Microphone Fits Hr2510 Hr...
My uniden president hr 2510 tx is stuck on
theres a VOX button on the front of the radio, is that activated? if so press it to shut it off
May 25, 2014 | Radio Communications
Looking tor owners manual uniden HR 2510 10 meter mobile transciever
Follow the yellow brick road...: http://www.uniden.com.au/resources_main/pdfs/HR2510.PDF
Jun 05, 2011 | Uniden Radio Communications
Sears garage door opener (GDO) model 139.53985D, only a couple of years old. 315MHz remote controls. Opener has stopped responding to the remote controls,unless a remote is held wihin 12 inches of the...
There is no way to change that radio frequency it is set by the government. Sears service technicians have an instrument to help them locate the interference that causes this type problem.
Oct 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
President HR-2510 will not transmit or recieve
Hi Darrel,
Since you didn't say if you have ever used this radio successfully before, I have to assume it is "new to you" and that you have never seen it work or used one like it before. Start with a few basic settings below:
Turn Squelch to minimum.
Set RF Gain (if present) to maximum
Set Mode to AM or FM
Set volume to 1/3 up
Connect to 50 ohm dummy load.
Turn power on. Hopefully you hear static. If not, try SSB or FM. Still nothing? Try connecting to an external speaker.
Chnage back to AM or FM mode. Key mic check & for transmit indicator. If none, change mic or manually short the PTT contacts in the mic or at the radio to see if it can be made to xmit.
If no xmit - insert SWR meter between xmitter and dummy load. Try to xmit on AM or FM again while watching SWR forward power, if none indicated, xmitter is probably defective.
Replacing parts in a xmitter is not recommended. You'll need an FCC license and a fair amount of expensive test equipment to test repairs, set power levels and deviation and perform an alignment to be sure you aren't causing interference on other frequencies and bands.
You'd be better off bringing it to a radio repair shop for repairs and an alignment.
Sep 29, 2009 | Uniden Radio Communications
Hp 2510 printer will reset, i have the hr glass showing
Can not find permanent fix, but with my 2510 if I unplug it for about 1/2 - 1 hour it starts properly.
Until the next power shortage of course, than I have to repeat the process
Jun 29, 2009 | HP PSC 2510 All-In-One InkJet Printer
Bose 3-2-1 remote control
But a new remote. Non repairable item. Just worn out.
Jun 07, 2009 | Bose 3 2 1 GSX System
Keypad Chaimberlain 32B2171-1 does not work any more
You can try programming but if it still doesn't work then your keypad is just bad. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in your 4 digit code and press enter.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Maytag MGR5875QD stove problem
bake and broil feature not even responding to touch???? its one component " the electronic range control" clock assy. after trying to unplug and possible resetting the control. i would say youll need to replace the control unit.
Mar 23, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
President uniden hr 2510 ham radio
I know these are old posted questions but here are some new answers..... Simplest first! Make sure the TX button is not engaged, if it is then the radio will not work correctly.
Second would be a bad final or driver, this is a tough fix as these parts are tough to find, the parts are no longer made. A fix has been devised using MOSFETs but I have little details on this.
Third but not last is to do with age and environment, a glue was used to stabilize parts to the boards, wire and coils typically. This "glue" will break down over time and exposure to moisture and become conductive, shorting out parts and also corrosive, making copper wire and traces come apart.
Lastly, incorrect bracket knobs with screw threads too long can actually "crush" the PC board and break the PC copper traces.
Dropping the radio is not good, cracked boards and broken wires in hidden places.
Repairs can be made on all these but you need a tech that has experience to find these.....
Nov 13, 2007 | Radio Communications
Radio Communications Logo
310 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
