Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Will not pick up fuel to fire up - Reddy Heater-170,000 BTU Kerosene Deluxe
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 69 Answers
Your unit has a air pump behind the electric fan motor. This pump is what produces low pressure air across the nozzle which causes a suction for the fuel pick up tube from the tank. Check your fuel filter first. If you are not getting any fuel spraying out the end of the heater, your air pump needs to be looked at. There are carbon vanes on a rotor inside the pump. They could be stuck in the slots of the rotor. Don't mess with any of the plastic plugs on the back cover unless you have the tools to test. Just remove the steel screws that hold the cover on. There will be another set of screw inside,remove them to get to the rotor and carbon vanes. If they are not stuck, your air pump may just need to be turned up. You will need a 10 lb. pressure gauge to test the pressure. It screws in to the 1/8" threaded hole (usually has a plasic plug) thats where the gauge screws in. The pressure on most heaters is 5.5 to 6 lbs. setting. The adjustment is the plug above the gauge test port. Turn clockwise to increase pressure/ counter clockwise to decrease pressure. Be careful because this will also increase more fuel to the combustion chamber. If turned up to high, you will get a large flame shooting out the end of the heater. If you do not have experience with working on the heater, and do not feel comfortable doing it, get someone else to help you that does. Good luck.
Posted on Jan 03, 2011
2003 buick regal wont start. It cranks but wont fire up. Would it be the fuel pump?
It could be a few things if it's petrol need to check if u got a spark if no spark could be a crank sensor if no fuel could be fuel pump could be a broken wire or immobiliser fault . If fuel low it could also be the pick up in the tank might be split or broke so can't pick up fuel. Hope this helps
Nov 22, 2014 | Cars & Trucks
My engine turns over but doesnt fire up
Check and make sure you have fuel pressure at the fuel rail, Then make sure you have spark at the plugs. If you have both spark at the plugs and fuel pressure at the fuel rail I would look at the pick-up in the distributor.
Nov 13, 2014 | Mitsubishi L200 Cars & Trucks
I have a 1996 chevy z71 5.7 vortec. we replace the motor with a new long block. all we had to do is put the intake on it. replaced the rotor and the pick up coil. checked fuel and getting fuel from the...
I believe I have answered this at least twice already. The pick-up coil is what tells the ECU to fire the injectors. If the ECU is not getting the signal then either the pick-up coil is no good, not getting power, or not properly grounded. The same for the ECU....it must get power, the signal from the pick-up coil, and a ground.
Jul 27, 2014 | 1996 Chevrolet K1500
1996 Chevy z71 5.7 vortec. Changed motor and put everything back together and it will not start. Have good spark and fuel. But not getting fuel to injectors. If I take and poor fuel in the intake it tries...
There are several things that tribute to how the injectors fire, but the ECU is what actually fires them, the pick-up inside of the distributor is what tells the ECU when to fire them.
Jul 27, 2014 | Cars & Trucks
Intermittant no spark. Cruising along and shuts off like someone flipped a kill switch
Gotta be either fuel, fire, compression or timing, so next time it dies, spray a little starting fluid into the intake, if it starts right back up -fuel problem-probably stopped up fuel filter, bad fuel pump. If not, remove a spark plug wire and attach old spark plug , lay it on a grounded metal part of the engine or frame , have someone try to start it, watch to see if the plug is firing.
Apr 30, 2017 | Haynes Ford Pick-ups and Bronco Repair...
1995 gmc sonoma five speed pick up will not start
process of elimination, in this order, make sure it has gas, make sure it is firing, the only 2 things to prevent it form running. if it is firing, check your fuel pressure , make sure it is getting fuel to the fuel rail(assuming this is a 4.3).
Mar 16, 2014 | Washing Machines
1992 Ramcharger We have no spark no fuel. Checked continuity from computer to sensors and installed new sensors still won't fire HELP
ok if its not the crankshaft sensor or pick up plate.
then look at your asd relay. cpu controlled via ground.
no fuel or fire. means pcm is not detecting engine rotation.
I remember bypassin the pcm ground control on some. just install
a switch to operate it.
Feb 15, 2013 | 1992 Dodge Ramcharger
Engine firing timing set getting fuel but wont run. pick-up coil?
If it is firing,and trying to hit,and popping and backfire some,or just is trying but not starting up and running,the pick up coil is most likely the problem.This year had a problem with the pick up coil after they got a few miles on them,make sure everything else is good.
Sep 14, 2010 | 1989 Chevrolet C1500
1997 jeep wrangler no fire no fuel replaced coil fuel relay ignition module crank sensor
Does it have a pick up coil under the distribtor cap if you dont know ask ato zone if your jeep has a pick up coil
Apr 07, 2010 | 1997 Jeep Wrangler
Throttle body injectors not fiering but there is fuel pressure
the injectors are fired thru the engine cotrol module but it gets its signal to fire from the pick-up located inside the distributor if you are loosing injector pulse only the ignition module is bad if you are also loosing spark when you loose injector pulse your pick up is causing the problem if you replace the pick-up i recomend you change the ignition module when doing so because they work together and you have to remove the distributor to change the pick-up
May 31, 2009 | 1994 GMC Sierra
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
