Question about Acer Aspire T120 PC Desktop
Hi We have an Acer T120 with a faulty power on off switch. The housing which sits under the switch on the front panel has broken. Do you know whether it is possible to buy a replacement part? Thanks Nick
  • 519 Answers
Hi Jean,
I don't believe it would be economically viable for you to purchase the front panel which houses the on/off switch. This may prove costly.
I would rather look out for a new case with power supply and transfer your motherboard etc. to the new case.
You should be able to get a new case & power supply from your local PC shop for under $50.
Best wishes,
Graemevm
Posted on Jan 25, 2012
The power window switch on front passenger door "sunk" into the door panel
Either the switch has broken off its lugs to hold it into place or the panel that it sits in has broken. You will probably have to strip some of the door or the panel the switch sits in to get the switch back. Once you have determined what has broken off, go to a wrecker or a Dealer and buy a new part. There will be wiring on the back of that switch. If the connections are single wires, make close note of what wire goes where. If its a plastic multiplug connection, they will usually only fit one way.
May 19, 2015 | Cars & Trucks
My acer aspire zc 606 desktop will not turn on. I have tried unplugging power cord holding power button down for 45 secs. Is there anything else I can do?
First, you should remove the power cord from the PC before opening the side panel. Second, you should avoid static electricity by touching a bare metal part of the case before touching anything else in the computer. It's possible that the power on/off switch on the front panel of your PC is faulty. Inside the case on the motherboard you will find several wires coming from the front panel which connect to pins on the board. one wire is labeled PWR. Unplugging this wire reveals the pins which are very close together. Using a screwdriver to touch both pins at once will power the computer on. Of course, the power cord must be reattached in order for this trick to work so be extremely careful! If the PC is still under warranty then attempting to replace the on/off switch yourself may void the warranty.
The other possibility is that the power supply, or the cpu, or the motherboard itself is faulty. In this case, take it to a computer repair shop.
Jan 31, 2015 | Acer Computers & Internet
Continuous blinking light on Panasonic Plasma
had the same problem wih my panasonic, it was a faulty power switch. make sure the power switch is sitting centrally in its housing, if not you may need a new switch
Jan 02, 2014 | Panasonic TC-P58V10 Plasma TV
Disabling driver signing for aspire T120
go to device manager, and by right clicking on the device you can disable it.
Jan 07, 2013 | Acer Aspire T120 PC Desktop
Acer t120 factory settings
hi...to restore pc to factory setting u need to have the CD for operating system installed in ur pc....if u have the CD please insert CD and keep tapping f12 and then press any key to boot from CD...there u get 2 option either to reinstall OS or to repair the PC ...u can choose repair option first if it fails then clean install the PC
Feb 11, 2012 | Acer Aspire T120 PC Desktop
Where can i get a new power supply for acer aspire t120
You can visit computer shop, they usually carry a stock or one can be ordered for your system.
Aug 10, 2011 | Acer Aspire T120 PC Desktop
Acer T120 built in soundcard installer
Go this site: Choose Desktops and OS to download sound card driver or installer
http://support.acer-euro.com/drivers/downloads.html
Nov 17, 2010 | Acer Aspire T120 PC Desktop
Pc wont power down
Sounds like a software application is not allowing machine to shut down. Try using the task manager to shut down all applications and processes manually, then try the shutdown option. If this works you will have to go through software apps one by one until you find the culprit. Hope this helps.
Dec 21, 2008 | Acer Aspire T120 PC Desktop
Power cord broken inside s251i miele How do i open the s251i ????
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
Dec 07, 2008 | Miele S251i Plus Bagged Canister Vacuum
How do I take my Miele S251i apart to be able to chenge the powercord?
Sep 13, 2008 | Miele S251i Plus Bagged Canister Vacuum
Acer Aspire T120 PC Desktop Logo
151 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
