Question about Panasonic PT-47WX51 47" Rear Projection Television
Will only tern on for a copple seconds then shuts off what do I look for to fix it
Tv tern on and tern off in 3 second
Fault at its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 07, 2015 | Televison & Video
What is the postcode for tern path glenrothes
Since I live in the United States I really don't know but a Google search came up with this.
Tern Path, Glenrothes Postcode KY7 6TN
KY7 6TN Postcode Information
Postcode for Tern Path is KY7 6TN
Town for Tern Path is Glenrothes
County for Tern Path is Fife
Longitude for Tern Path is -3.1802191
Latitude for Tern Path is 56.2145598
Morse code for KY7 6TN is Kilo Yankee Seven Six Tango November
Sep 16, 2014 | GPS
Humax Receiver not working
Tern off the device remove LNP cable then tern on the device again without satellite cable and wait for seconds the massage will gone. Reconnect LNP cable and enjoy it again.
May 06, 2013 | Humax Televison & Video
Entering keys receiver humax ir free
May 05, 2013 | Televison & Video
The security code for my pioneer deh-p6500
This deck doesn't come with a secuirty code installed, the 1st owner must install the code, so there is no way to know what that code may be. Are you the 1st owner? Call Pioneer and see if there is a way to get around this problem. They may ask for proof of ownership.
Jan 18, 2012 | Pioneer DEH-P6500 CD Player
My w\vista when i first tern it on and the compact
Ouch. I hope you didn't break anything. I would take the battery out of your laptop and then put it back in and make sure the battery isn't dead. USUALLY when a laptop powers off it is a power issue. However, since you said you dropped it, there may be other motherboard damage and it may need to be serviced.
Aug 27, 2009 | XFX GeForce Fx 5900xt Graphic Card
Electrical help
First, check battery voltage. Since you've done a lot of work, Perhaps you have something in the charging system malfunctioning or improperly connected. Does anything work with the vehicle jumped or with a known good battery installed? I'd go there first, then start tracing wiring and checking all connections and grounds!
Dec 14, 2008 | 1994 Jeep Wrangler
Monitors video and power blinks on and off
Yet another case of bad capacitors on the power board.
These monitors are well known for this issue, but they live a long time past when they should.
Easy repair, but if your not confident around electronics drop it to your local TV repair shop.
Hope it helps =)
Mar 06, 2008 | IBM ThinkVision L170 17" LCD Monitor
Cover display not tern on
fix your front panel, the display might be broken. try to use the phone from the inside panel. if it works, do what i tell you.
good luck
Feb 15, 2008 | Nokia 9500 Communicator
Panasonic PT-47WX51 47" Rear Projection Television Logo
227 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
