Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
Fuses Any tips on how to get to the fuses? It is a built in and we don't see any obvious places to access fuses.
  • Anonymous Nov 25, 2008
    I need to know where the fuse box is for my oven. I have a new switch with thermostat in but the oven or grill does not work. The thermo fan & light does not come on either. All the plated on top, work.
On the kitchen aid double oven the thermostat cut out fuse is located on top of the oven behind the control board and display. undo the srews and move it a little to the right, you will see a blower motor
sitting on top, just behind the blower sits the fuse. very easy to change, make sure the power is off to the unit before working on it. This is your problem if the oven stopped working after self cleaning. the deplay will be dead and no oven light
Posted on Nov 29, 2008
    President:
  • 1,314 Answers
You will have to slide the oven out and remove the top panel of the range its not as hard as you will think consult your owners manual for revering the installation instructions shut the power off then remove the top panel under the cover on the right side is a tech sheet which will help you locate the fuses on the left side of the microwave
Posted on Jul 12, 2008
Lower oven will not heat, circuit fuse is OK
You will have to remove the unit, to access the back and pull the covers, most likely you coil is burned out. Or a safety fuse to the coil is tripped last but not least, your control card is burned out. Might want to give make and model
Nov 11, 2015 | GE Jkp90Dpww 27" Built-In Combo Microwave...
How do i change the bulb in a brother hi speed cooker microwave . It is about 30 years old and works very well
If no access from the front you will have to get at it from the back. Remove the back covers, the light socked will probably be held in place by a few screws or clamps. remove the entire assembly as one unit, replace the bulb and re-install.
Aug 16, 2014 | Ovens
My oven does not turn on
HELLO.
It is obvious that there is no electric power supply in your microwave oven.
solution
The problem of your microvave is likely to be from the fuse or wiring connection connected to the panel.
What you need to do fix up the problem from easy to hard , first of all is to carefully unplugged the plug from the wall then allow it to relax for some time then plug it back again to the power supply correctly to see if the problem will be solve ,
Then take a look on the fuse and also the wiring mention above the fuse is some time located at the tip or the mouth of the plug depending on the type of the wiring connection on the oven or inside the oven it self which will need to be check on and same condition is apply on the wire as well.
Please get back to me for further instruction if necessary.
Thanks.
Sep 19, 2011 | Stoves 600GR Gas Single Oven
We have to replace the control panel on our Amana AOES3030E wall oven. We have the part but how do we access the area where the new part needs to go? I'm not seeing how in the user manuals I looked...
To replace the control panel, the wall oven needs to be pulled out about 10-12 inches to access the conrtol panel..it has screws on the side AND in the back of control panel taht have to come off to get into panel...typically it can be pulled out fairly easy a couple of feet without it tipping and falling out of cabinet but only pull out as little as necessary
Aug 25, 2011 | Amana AOES3030 Electric Single Oven
I've got an Hoover HDC884X Built in Electric Double Oven. Can you tell me what I need to do grill toast. Don't understand the knob controls and the manual doesn't help as it is too generic
Hi, I understand your frustration, the manual supplied is next to useless! The 'obvious' settings appear NOT to work (as the grill remains on full heat setting all the time). The only way we've managed is to lower the food away from the grill..... not ideal I know - but also we don't use it for toast.
I suppose Hoover would be the next best port of call for assistance, oh for a proper manual, not a horrible generic one that attmpts to cover every model they produce - AND FAILS.
This is purchasers main complaint about buying Hoover ovens it seems.
I'll come back to see if anyone can supply a solution to our problem.... and hope it's not a fault in manufacture.
May 05, 2011 | Ovens
Microwave has no power. It is a combo oven/microwave built-in oven and the microwave has no display or power to the interior light. Is there a fuse location or a way to re-set the oven?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uu
Sep 27, 2010 | Ovens
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Built in Convection Microwave Oven KBHS109SSS
no reset buton persay but fuses and control boards. MICROWAVES emit and store HIGH VOLTAGE nad should only be access and repaired by trained proffessionals. NO JOKE HIGH VOLTAGE. like your DEAD VOLTAGE
Nov 20, 2008 | KitchenAid Architect Series KEMC308KSS...
GE Advantium Microwave portion not working
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
Heating elements do not heat
it sounds as if you have a tripped thermal cut out. This is accessed by removing the 5 or so screws on the black grate below the control panel and pulling the grate out. Somewhere in the middle towrds the front should be a little button wiht 2 wires hooked to it. make sure you have the power off to the oven, then reach in with a screwdriver or your hand if you can and push the little red buttton down untill it clicks. The cause for this to trip could be bent door hinges not allowing the door to close fully (common thermadore problem), bad door gasket especially in combination with running a self clean cycle, broiling with the door ajar, or a bad cooling fan (the one behind the electronics, not the one in the oven) Hope this helps.
Jun 16, 2007 | Thermador SEC301 Electric Single Oven
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
291 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
