Question about Ovens
Re: GE JTP45 oven - the top door does not shut all the way. I know how to remove the door, but this doesn't seem to let me remove the hinges. I have tried removing the two screws, but there doesn't seen any direct way to get the hinge out. Do I need to remove the front frame first to get the hinge out? If so, how do I remove the front frame?
  • 552 Answers
Click on the link below to watch a video that explains how to remove the door on most modern ovens.
http://www.appliancerepairlesson.com/2011/01/22/oven-door_diy-oven-repair-help-101/
Posted on Mar 06, 2011
    Problem Solver:
  • 15 Answers
You may have to dismantle the door. Clean the glass while there.
Posted on Jan 04, 2011
  • rbkleiman Jan 04, 2011
    I know how to remove the door. The hinges do not come out with the door. How do I remove the hinges from the frame?
  • Denis Colbourn Jan 05, 2011
    This is more difficult. Sometimes the mechanism with the spring is held in by 2 screws, othertimes it is built in to the oven when assembled and is a much harder job. The oven needs to be removed, the outer case removed so the mechanism is exposed. The availability of hinges would need to be explored before this is attempted. I have only seen these when dismantling an oven.
    good luck.
Removing oven doors
  • Trying to clean a late 1970s Hotpoint GE Wall Oven Model "R K746 013AD" and
  • I do not know how or if the oven door is removable.
  • See photos.
  • I am able to remove the side of the door hinge attached to the oven but am not sure about the hinge attached to the door.
  • I do not have the owners manual.
Jan 01, 2014 | Ovens
Electrical panel goes out when top oven gets hot jtp45
Sorry dearest
We in the wilderness are not familiar with that brand, sorry
Kolbrun
Apr 09, 2012 | GE JTP45 Electric Double Oven
GE JT980 double oven door issue: I have a GE jt980 which I just bought from a cabinet company that used it as a display. It was never used, but when I picked it up, they had taken the upper door off, which...
Make sure the oven door hinges are open fully and locked then reseat making sure the notch on the bottom of the hinges seats on the cabinet locating plate, then release the hinges and close the door....theese hinges can take your fingers off so be very careful
Oct 11, 2017 | GE Profile JT980 Electric Double Oven
Door to oven does not close completely - how do I access the door hinge to check or replace it?
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
Jan 02, 2011 | GE JTP45 Electric Double Oven
I have just installed a new electronic control in my JTP45 Electric double oven. (part WB27K5273). I have a schematic, but so far have not figured out why that when I open the door the unit turns off and...
It does sound like a wiring mistake. Check all the connections and the wire colors against the colors on the Tech Sheet wiring diagram (which is normally taped on inside the control panel). Particularly look closely at how the door switch and lock connector is plugged in. You may have reversed the plug.
Best Regards,
Bruce
www.fixyourboard.com
Jun 18, 2010 | GE JTP45 Electric Double Oven
Install new element in upper oven lower element
unplug unit from 240volt outlet or if hardwired shut off circuit breaker at house panel, remove 2 screws at where element leads enter oven cavity and pull out element,you may have 2 terminal screws to remove electrical connections from element if it doesn't plug-in, then reverse procedure and its done
Sep 12, 2009 | GE JTP45 Electric Double Oven
Oven door does not close
One of the springs fell off or the door hinge assembly sprin out.
May 04, 2007 | GE JT912SKSS Electric Single Oven
Ovens Logo
150 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
