Question about Canon imageRUNNER 210S Copier
Canon IR210s copier
How do I change toner? I can't get toner in or out!
  • mpearson Aug 27, 2008
    Can't get the black top off to insert new toner cartridge
  • Canon Expert
  • 1,326 Answers
Are you sure you have the right toner??? It says it is for the IR-200-210 or dose it say IR-330 & IR- 400? If you look on the inside front door cover there are pictures showing how to install the toner, also there are pictures on the box the toner came in and also the display sceen will walk you through on how to replace the toner.. It slips in only one way and push down on it till it locks in then pull the blue tab till it displays "STOP" then push it back in and the push on the black part on the front of the developer unit to release the toner bottle and close the copier back up and lok the blue lever to the left and you are done. Good Luck
Posted on Jul 10, 2008
How to change toner
Normally the procedure is indicated in the manual. Check the manual of your unspecified printer or copier.
Procedure is different on each device. Just for your illustration, enjoy some videos about how to replace toners on copier:
How to Replace Toner in your Ricoh Copier
SHARP COPIER How to replace toner cartridge
How to Replace Toner in Canon ImageRUNNER Copier
Toshiba copier 2006 toner change
Aug 07, 2015 | Office Equipment & Supplies
Canon ir 1020
I have canon printer ir 1020, when I need to change a toner the printer detect if the toner that i have putted is empty, but the toner is the new one. what is the problems/ and how to fix it?
Sep 03, 2013 | Office Equipment & Supplies
How to change color toner on Canon C6800
Open front door, you will another blue cover in the centre, colour that neds changing will be exposed.
Jul 25, 2010 | Canon imageRUNNER C6800 Copier
Canon Ir2018 always indicating ''no toner, change toner''
Because you need to clean and shake the toner unit. When you say " ive been fixing" does it mean that you now what you are doing or?
If yes dismantle the toner unit and vacume it, it may be that toner stucked on "antena" for toner recognitions.
If not - call service
Pls. rate
Apr 27, 2010 | Canon Office Equipment & Supplies
How do you change the toner in an imagerunner 2270 copier?
It's under the small fold down cover situated front right.
Just above and to the right of the canon logo.
Jun 16, 2009 | Canon Office Equipment & Supplies
'How can i attach my ir210s with computer to print'
This can only be done if the machine has a print board installed. They no longer are available from Canon. If you look at the side where the paper comes out, towards the back side of the copier, you will see a few removable silver metal plates if no board is installed. If it is, you will see a computer network jack. If it has this jack, then it might be possible to download the drivers from the Canon website. These machines use TCIP printing. Contact me here if you need further info.
Hope this helps,
Jan 03, 2009 | Canon imageRUNNER 210S Copier
E240 error
it is most likely a burned out scan lamp.
Dec 24, 2008 | Canon imageRUNNER 210S Copier
Canon ir210s gatting error E100
that is a defective laser error code sorry
Dec 23, 2008 | Canon imageRUNNER 210S Copier
Color toner
try this on the screen you touch system moniter then consumables this should gine you a divided screen on top toner levels on bottom should say change each toner select the ones you want to change
Nov 04, 2008 | Canon imageRUNNER 210S Copier
Canon IR210s
error code E064 resulting due to transfer roller being dirty or requires replacing . please note transfer roller operates on high voltage .
Oct 03, 2008 | Canon Office Equipment & Supplies
Canon imageRUNNER 210S Copier Logo
212 people viewed this question
old marine
old marine
