Question about Samsung Computers & Internet
My cpu is on just i power off the monitor.,series is samsung SyncMasterB1930 is the model., now when i am trying to on the monitor the monitor is not responding it is still power off mode.
  • 442 Answers
First check if the monitor is functional by removing the monitor cable connected to the CPU, once disconnected you should see a onscreen display on the monitor (Keep the power cable intact).
Second check if the CPU is working (not stuck / hung) if you hear the windows logging on sound, then your CPU is fine. If you do not have sound enabled during startup or no speakers then once the system is on give it some time to load windows and then keep tapping the Caps lock or the num lock key, if the lights respond / glow on and off when you press the keys then the CPU is working.
Third check if the CPU has two display ports (in case if you have a onboard VGA and a seperate video card) disconnect it from one port and insert it in another port and restart the computer and see it it works. If you do not have two video ports then skip this step.
Fourth - Restart the computer and keep tapping F8 Key while restarting, in the windows advanced menu choose enable VGA mode or Low resolution video mode (based on XP or Vista/Win 7 the menu changes), if you can see that menu then the issue is with the display settings only. Once in VGA mode or low resolution mode reduce the video resolution settings and restart the computer.
Please revert if you need further assistance, or clarification.
Thank you for contacting Fixya
Posted on Jan 03, 2011
When i plug to the cpu monitor cut off the power and green light is blinc
Do one think just plug out Monitor to CPU cable , just on monitor only if so can you able to see one small icon go top to bottom its like keyboard, if you can see that, you don't have any problem on your monitor.
step 1 - just remove ram slot and insert again try to ON your system now
step 2 - take your cpu and connect to other monitor and check where it getting on or not , if monitor get ON and work good mean you don't have problem with your CPU , problem was in monitor to cpu cable ,so change your monitor cable its just cost of 4 to 5 $.
step 3 - take your monitor connect to another CPU , check weather you getting same problem if it work good mean, your CPU motherboard have problem just call your hardware engr to solve it,
GOOD LUCK ! if your problem solved don't forget to rate
Dec 31, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
I bought a lcd monitor samsung syncmasterB1930 and it requires 1324*1068 screen resolution. i have installed the drivers for the monitors but still unable to get the desired resolution. is there any way...
The native resolution if this monitor is 1440x900 - i have no idea how you end up with that weird resolution. In any way it will not accept a higher resolution.
Nov 23, 2010 | Asrock 775I65GV...
Powers on then back off in two seconds...I don't know how to open the case without destroying it..
hello,
Seems that your problem is not your Samsung Monitor. Please check very well. Since this is basically an indication that your CPU is not working that is why there is no display in the monitor and the yellow light turns to orange.
  1. Please try to use another monitor if you still have one that is working well. Then power up your computer and see if there is display on the monitor. If there is, then your reported monitor really has a problem. And if there is no display even in the new working monitor, then the CPU is in frozen state that is why there is no display on the monitor.
May 08, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My wife's mom bought us a desk top p.c with this samsung 906bw
Well, seems like the CPU is the source of the problems, not the LCD Monitor.
The simple way to check it is by remove the cable from CPU unit, see for any sign such us color pattern moving or any sign.
the other way is, try using other CPU or Laptop, then connect it to the LCD Monitor.If it works, then you need to repair your CPU.
Hope it's working
Feb 22, 2010 | Samsung 906BW LCD Monitor
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Cpu turns on but monitor not
PLS CHECK THE POWER CABLE ATTACHED TO THE MONITOR AND THE CPU..IF CPU IS WORKING PROPERLY THE PLS CONSULT YOUR VENDOR.THER MIGHT BE PROBLEM IN YOUR MONITOR
Jul 22, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Does samsung monitor save power in sleep mode?Or will it just displays black all over the monitor?
yes, all monitors work directly with the cpu, the cpu sends message to the monitor, so if the system is in sleep mode, automatically the monitor stops work excepts the cpu comes up again then the monitor wakes, in a nutshell, a monitor is connected to power while in sleep mode but has no signal to function
Jul 16, 2009 | Smart Modular SV3170A
Samsung lcd
First It is not your monitor problem the problem is in your CPU
Open the Cabinet (CPU) door Took out RAM (Random Access Memory) after 5 miniuts Connect it
Thank U
Apr 15, 2008 | Samsung SyncMaster 203B LCD Monitor
Computers & Internet Logo
56 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
