Question about HP CC3310 (a9863a) Server
Disk (disk0-p1) has failed. Disk has failed. - HP CC3310 (a9863a) Server
When i start my emac no desktop icons, dock or menu appear. Only my background photo.
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica; min-height: 14.0px}
Check for a failing hard drive
Trying booting from the Mac OS X install disc.
insert the Mac OS X install disc.
press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
Nov 21, 2010 | Apple eMac G4 Desktop
My ibook (G3 700 two USB) stars but the screen continues to be dark I willl like restart, without any problema about data
Nov 20, 2010 | Apple iBook G3 Mac Notebook
Hello my boot disk is crash now. so , had to
Maybe rescue the data by booting from a LIVECD like PUPPYLINUX and transfer all files to a working hard disc. then reinstall system.
Feb 13, 2010 | Computers & Internet
Installed a new internal hard drive and when I try to boot up the machine does not recognize the new hard drive. There is no item in the select which drive to load from.
Boot off the install disk with nothing else attached to the PC. ( external hard drives especially ).
Choose ‘Terminal’ in the ‘Utilities’ menu
Then (substituting the correct values for your setup), type:
diskutil partitionDisk /dev/disk0 1 GPTFormat JournaledHFS+ my-hard-disk 111G
It’s all one line and hit return at the end.
You should see progress information, followed by a neat table giving the new formatting that has been applied.
‘/dev/disk0’ is how the operating system refers to the first whole disk in the system.
Then, the ‘1’ here signifies that you want one volume only on the drive.
Then, replace ‘my-hard-disk’ with the volume name you want to use. This is the name of the disk as it appears in the finder.
Replace ‘111G’ with the size of the disk in gigabytes. It’s usually about the same as the disk, and as the partitioning software will stretch a single partition to fill the disk it doesn’t matter too much. 111G was the value used for a 120GB HDD, because I knew that it wasn’t really 120GB.
Hope this is of some help.
If not a solution ( hard one to do over the net :) ) hopefully it will point you into a solution.
Oct 17, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Data recovery
Unfortunately, a three disk RAID 5 can only tolerate a single drive failure. Is it possible that disk 0 and disk 1 were reversed? If so, then you might be dealing with only one failed drive and might be able to rebuild the RAID if you get disks back where they belong.
Otherwise, you will need to send the disks off to a data recovery service and hope for the best. This is only viable if the data is very valuable as this will be very expensive. Typically more than $1000 just to evaluate and diagnose.
Jul 09, 2009 | IBM eServer xSeries 225
Problem with Fujitsu MHT2080AH hard disk drive
Nothing can be done that is as cost effective as buying a new drive. Use the drive as little as possible, back up your data before it dies completely.
A professional could rebuild it for a few hundred dollars if you have a particular attachment to this exact model. But I can't think of any reason one might choose this route rather than simply buying another drive.
Feb 22, 2009 | Fujitsu MHT2080AH 80 GB Hard Drive
How to create owr own calculater
for all os ? you must use java language! this is the code:
//<applet code="calmayank"height=300 width=300></applet>
import java.awt.*;
import javax.swing.*;
import java.awt.event.*;
public class calmayank extends JApplet
implements ActionListener
JTextField t1;
JButton b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,
b11,b12,b13,b14,b15,b16,b17,b18,b19,b20;
GridLayout gl;
JPanel p1,p2,p3;
public void init()
gl=new GridLayout(5,4);
p1=new JPanel();
p2=new JPanel();
p3=new JPanel();
p1.setLayout(gl);
t1=new JTextField(17);
b1=new JButton("1");
b2=new JButton("2");
b3=new JButton("3");
b4=new JButton("4");
b5=new JButton("5");
b6=new JButton("6");
b7=new JButton("7");
b8=new JButton("8");
b9=new JButton("9");
b10=new JButton("0");
b11=new JButton("+");
b12=new JButton("-");
b13=new JButton("*");
b14=new JButton("/");
b15=new JButton("@");
b16=new JButton("$");
b17=new JButton("%");
b18=new JButton(".");
b19=new JButton("?");
b20=new JButton("=");
p2.add(t1);
p1.add(b1);
p1.add(b2);
p1.add(b3);
p1.add(b4);
p1.add(b5);
p1.add(b6);
p1.add(b7);
p1.add(b8);
p1.add(b9);
p1.add(b10);
p1.add(b11);
p1.add(b12);
p1.add(b13);
p1.add(b14);
p1.add(b15);
p1.add(b16);
p1.add(b17);
p1.add(b18);
p1.add(b19);
p1.add(b20);
p3.add(p2);
p3.add(p1);
getContentPane().add(p3);
b1.addActionListener(this);
b2.addActionListener(this);
b3.addActionListener(this);
b4.addActionListener(this);
b5.addActionListener(this);
b6.addActionListener(this);
b7.addActionListener(this);
b8.addActionListener(this);
b9.addActionListener(this);
public void actionPerformed(ActionEvent e)
if(e.getSource()==b1)
t1.setText("1");
else if(e.getSource()==b2)
t1.setText("2");
else if(e.getSource()==b3)
t1.setText("3");
else if(e.getSource()==b4)
t1.setText("4");
else if(e.getSource()==b5)
t1.setText("5");
else if(e.getSource()==b6)
t1.setText("6");
else if(e.getSource()==b7)
t1.setText("7");
else if(e.getSource()==b8)
t1.setText("8");
else if(e.getSource()==b9)
t1.setText("9");
Dec 15, 2008 | Computers & Internet
Cant partition, format maxtor drive
Connect drive to be formatted as slave.
to check if your windows sees the drive and is it active go to your desktop and right click on my computer -> manage -> Disk management.
You should see something like the picture below:
Your first disk will be Disk0 and 2nd disk will be Disk1 If you cant see Disk1 then the drive is faulty OR not connected properly make sure the drive is working with cables attached.
Listen if the drive spins.
If it doesnt then something is wrong.
If you can see the drive there then you might not have made any partitions onto it. You can make new paritions to the disk right there, right click on your disk1(your 2nd hdd) and create a new partition.
Mar 23, 2008 | Computers & Internet
Dawoo DVD Player showing No Disk error
you have dirty lens, try to cleaning with 100% cotton buds. or you have damage laser eye, or broken flex ribbon wire, but first you have to do is to cleaning the lens with cotton buds.. if not reading after you clean the lens! change the laser eye and flex ribbon wire.
Aug 31, 2007 | Daewoo DVDS151 DVD Player
HP CC3310 (a9863a) Server Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
