Question about Kenmore 24032\24036 Top Load Washer
My washer has not been working correctly it iwill not spin to finish the cycle. what has gone bad?
    Problem Solver:
  • 18 Answers
A very common problem with these washers is that the switch that senses when the lid is closed goes bad. The washer won't spin if it thinks the lid is open. This switch is located in the rear right hand corner of the washer opening. It is an oval hole with two small phillips head screws adjacent to it. You might take a pen or pencil and push down on the switch in the opening. If you don't hear or feel a distinct click, the switch is probably bad, but it could still be bad even if you hear a click. If you unscrew the two phillips head screws, you might be able to work the switch out to where you can check it out more closely. If you can determine this is indeed your problem, you should be able to buy one online at a reasonable price, and you might be able to search this site for complete directions how to replace the switch.
Posted on Jan 06, 2011
Kenmore 400 series washer won't finish cycle,I have to turn the dial to drain and spin to finish the load
Sounds like either a wire has come loose from the switch or the motor that spins the the ( may be integral part of switch ) has gone bad.
Mar 07, 2016 | Kenmore Washing Machines
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
I have a Bosch Nexxt 700 Series Washing Machine. We have been emptying our washer by shop vac for a couple months now. Nothing in the pump. Once through the wash cycle it will try to drain and then flash...
Is the pump pumping? Have you cleaned all the drain lines including the discharge hose? You may have nothing in the pump but it could be blocked somewhere else.
Apr 24, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
Agitator does not spin clothes during wash and rinse cycle.
Hello , iwill try to help you with your washer problem.. so your washer fills up and when lid is engaged with a screw driver into the lid switch thw washer makes noise like its agitating but is not agitating or spinning sound like your ( coupler has gone bad .. A coupler is kinda like a belt it syncronises the transmision to the motor it is part #285753a around $20.00 dollars on the parts break down it is item number 13 check under the washer for black rubber pieces 10042888-00006.png if you need step by step instructions you can always call me for phone technical support...dr.appliance
Feb 23, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin Cycle "Whines" and keeps spinning after cycle is complete
need make & model # to correctly solve problem, it could be timer shorted or the drive motor has gone bad.
Oct 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothes are sooaking wet when cycle finishes and they smell bad
The wetness is due to the spin cycle either not working properly or not being allowed to finish. For the smell, with the washer empty, run a cycle on hot/whites with bleach only, after the first cycle drains, open the washer and add more bleach directly into the washer.
Apr 20, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
Kenmore 24032\24036 Top Load Washer Logo
323 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
