Microsoft Xbox 360 Console Logo
A
Anonymous Posted on Jan 03, 2011
It takes about 10 minutes of restarting and opening my disc tray until my xbox reads that there is a game or dvd in the tray! and it then sometimes says there is trouble reading the disc. Is there something wrong with the laser reader?
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Jan 03, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
1822
Points
46
The laser could be dirty, meaning it has a build up of dust, etc on it. Try using a cleaning disc, which is specially designed to clean CD, DvD and other electronics with a laser reading system. You can find these at your local electronics store, Walmart, Target, etc. They are readily available. If that doesn't correct the issue, then you may need to take it in to a specialist.
  • suri1987 Jan 04, 2011
    there is something wrong with the laser reader.The laser could be dirty.
    You need to take care. http://timermall.com
I Played COD Black Ops Two Days Ago And Now I'm Getting This Open Tray Error.. I Tired Blowing In It, Cleaning the Brand New Disc off It Reads It Sometimes and Then Says Open Tray... Help Me
I have the same preoblem with my 360. Try to take the disk out and power off the console. power it back on and let it start up without the disc inside. After this turn it off and restart the console. Put the disc in and it should start.
Its a problem with the sensor in the DVD drive of the console. You warranty may still cover it so if it continues I would call Microsoft at 188-4-my-xbox.
1helpful
XBOX 360 cd rom is not reading discs
1. Make sure you REMOVE any discs from your XBOX' tray. 3. Turn on the console again, either by using the controller or the POWER button (NOT the EJECT button) and WAIT for the initial XBOX setup. ... This fixes the OPEN TRAY error 100 % of the time on my XBOX 360. XBOX 360 cd rom is not reading discs Google Search
Does not read disc
use a dvd lense cleaner if that doesnt work take it to a game shop it prob the lasor.
2helpful
When i place a disk in my Xbox 360 console it
I have had this happen about 3 times. The first time was when i figured out how to fix it. The 2nd and 3rd were temporary.(Just needed to be turned off for a moment) You need to shut the console off for atleast 15 minutes 10 at the lowest with everthing unplugged. I mean the hard drive, memory unit, and all cables, and adapters. Then after 10-15 minutes plug everything in and DON'T PRESS the BUTTONS ON THE XBOX OR THE CONTROLLERS. Press the button to open the tray and take out the game or dvd and put in a different one. If this doesn't work do it all over again and then put in a different game or dvd not the previous ones and turn on the console the same but then a soon as you get the disc in and closed in shut it off then open the tray and wait till you are at the main menu go into any program so you can't see it is reading and close the tray. If that doesn't work contact the xbox support line. Really hope this works for you.
My xbox just says open try
1helpful
4answers
My xbox 360 doesn't play my games
check if you CD is break in the center. If it break, go in a EBGAME and told them your problem.
3helpful
2answers
I turn on my xbox 360 and it says open tray and wont read disc
14helpful
3answers
My xbox says open tray when there is a disc in it
common xbox flaw mine does the same ,just keep opening and closeing the tray till it reads the disk,this can be very annoying .your dvd tray is probally on the way out
Xbox 360 problem
might be lens problem or alignment on dvd tray
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
