Question about ASUS P5LD2 Motherboard
I have a p5ld2deluxe motherboard with XP OS , wireless logictech mouse@K/B has worked fine forever. we had a power outage ( i do have surge protect.) but now when i turn it on the POST will come on and beep 1 time ( all is good signal) and the OS will load, and will go to the windows account page ,but mouse will not move from the middle of the screen and the K/B will not function. and when the system powers up , i cant even get into the sysstem config. no function of mouse or KB at any stage of operation. what can i do ?
sandrew
  • 2961 Answers
SOURCE: Motherboard not starting Bios but fans start
Yes, had exactly the same problem earlier this week, the bios chip may be faulty, as you know all other components work, so it's down to the motherboard and a replacement is required
Posted on Mar 22, 2007
Tech Jenkins
  • 359 Answers
SOURCE: Windows XP not starting after power outage
I have just in fact a few days ago came across a similar issue. As to whether or not your hdd needs to be replaced is uncertain. What I can tell you is it seems as though the MBR or master boot record has become corrupt or one of the reader arms inside the hdd has failed.
Refering to the corrupted theory, may be simply fixed by booting off of a win xp cd and reformatting your drive and reinstalling windows after the format.
HOWEVER
In my case even booting off of a xp cd did not resolve the issue, every time anything would attempt to read from the hdd the computer would reboot. I suspected hdd failure at first, but this was not the case. It turns out it was a virus that infected the ntfs.sys and the MBR and put a binary code into those 2 files to reboot the machine.
Luckily at work (IT industry) I have a norton ghost server and was successfull at reimageing the hdd, doing so erases the MBR and everything else for that matter and rewrites it. However in doing so I lost all data that was on the hdd to begin with.
If you are not very tech savvy I would probably recommend hdd replacement however since you do have a HP which was prebuilt with xp, you don't have a xp install cd and thus unable to reload windows. I recommend finding a friend that has the xp install cd or you will have to go to the store and buy XP.
Posted on Nov 19, 2008
jell587
  • 447 Answers
SOURCE: Upgrading of OS from Windows XP to Windows Vista
I looked up your motherboard and found some posts that suggest that the onboard VGA may be the problem you're having with Vista - using an another video card will probably allow you to install and operate Vista on your machine.
Posted on Apr 02, 2009
sodeep
  • 3267 Answers
SOURCE: A7V400-MX will not boot
In such cases its practical to change the SMPS with a working power supply of the same rating and then trying it out. If with the new power supply it works fine then cange your SMPS. Also make sure that all cables are snug tight and generally ree from dust. The same applies to your RAM too................sodeep
Posted on Apr 18, 2009
hacker8499
  • 74 Answers
SOURCE: asus p5kpl-am in USB and Sound not detectiing
try to make an adjustment on your bios i think usb is disable try to enable it and sure all your usb will work.
Posted on Oct 14, 2009
AFTER FEW POWER OUTAGES, FREEZER TEMPERATURE KEEPS BOUNSING BETWEEN 5 AND 20 DEGREES, REFRIGIRATOR SEEMS TO WORKING FINE AND KEEPS TEMPERATURE.
Check the cabinet temperature with an independent thermometer. If it is does keep a stable temperature the problem would probably be electronic.
A power outage is often accompanied by a voltage surge. Sensitive electronics and computers can be damaged by a voltage surge. People are used to protecting personal computers with surge protectors but fail to realise these days almost everything is a computer or contains a computer. Radios and tv sets are computers and so are cars and even the humble toaster these days has some computing power.
Today almost everything but the cheapest of appliances should be protected. A minimum surge protection can be obtained by using an area surge protector.
Aug 18, 2016 | Liebherr Refrigerators
Bizhub C203 just takes itself offline
have you try a different battery back up and surge protector there is stll a possibllity it did get damage any how.
Feb 05, 2014 | Konica Minolta Office Equipment & Supplies
I had a power outage & now my pc won't turn on.
It is possible that either the power supply or the motherboard is faulty.
Try swapping out the power supply (borrow one if you can) and if the PC power LED does not light up or the PC boot up, then you need a new PC.
I suggest you get a surge protection power board and connect your new computer to this surge protection power board. It will protect your computer from power surge problems.
Mar 31, 2011 | HP Computers & Internet
Alarms will not work
Hi. Often following a power outage there is a power surge when the power is restored. If you do not have your Bose protected by plugging it into a surge protector, an internal fuse will blow to protect the rest of the radio. Once that fuse is replaced you will be back up and running. J.
Jul 09, 2010 | Bose Wave Radio II
Had a lightning strike last night that shut the computer down. With a "snap" sound. Rebooting goes through XP Startup screen, then only desktop wallpaper shows. Mouse moves, nothing obvious to me in the...
power surges generally damage power supplies or mother boards
smart operators use surge protection board or UPS unit s to lessen potential damage
Take it to a repair shop for a diagnosis
Nov 01, 2017 | ASUS A7V600 Motherboard
OS 10.4.8 / dock not recognized by wireless mouse
Hello, It seems like your hard drive didn't like the power outage at all. You can try to repair your disk permissions and volume: - Insert your install DVD - Reboot and hold the "C" key at startup - CHoose english, and go to the tools menu at the top of the screen - Choose disk utility, - Select your volume in the SOS tab, then click "repair permissions" - Click "repair disk" also
Jun 11, 2009 | Apple iMac Z0CY Desktop
Replaced my power supply, now keyboard and monitor wont work.
Believe it or not, if you have a floppy drive in your computer, try unplugging it and disconnecting the data ribbon. Many times, damaged floppy drives can short out motherboard functions and even prevent computers from powering up. If that doesn't fix it, then get a usb keyboard and mouse set (wireless would be fine) or borrow some, and see if they work. If they do, then the power outage damaged the PS2 ports.
May 25, 2009 | E-Machines eMachines Monitor E15T4
Wireless mouse not working
try another port,still not working,try another mouse.
Apr 26, 2009 | Computers & Internet
ASUS P5LD2 Motherboard Logo
89 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
