Boiler comes on but radiators not heating - Heating & Cooling
    Problem Solver:
  • 14 Answers
Each radiator has a shut off valve - make sure all the valves are turned on.
Posted on Jan 03, 2011
Boiler runs but not getting any heat coming out of the radiator
When you have a call for heat from the t-stat, the first thing that happens at your boiler is the circulator turning on. Turn off the stat, let the boiler cool down, and stand by the boiler when someone else turns the stat on. Put your hand on the circulator. If you feel it start to run when the stat is turned on, it's OK.
If it's not the circulator,then it sounds like the system is airbound and must be purged.
If you have actual radiators instead of baseboard, then each radiator must be bled. You can get a radiator key from any good hardware store. It may take a few circuits around the house to chase the air down so bleed each radiator at least twice.
Mar 19, 2017 | Heating & Cooling
Tip
Hot Water Steam Efficiency Plus Comfort
Steam heat is a great warm, wonderful, and absolutely fabulous way to heat your house. Steam heat is almost always created from water in a boiler fueled by gas, oil or electricity. It then passes through pipes and radiators or convectors to heat your home. A steam heating system uses steam that is generated from a boiler. When the water boils, the steam rises through the pipes and into the radiators to heat them. The hot radiators then heat your home.
Steam is a great heat distribution medium because it moves easily through your system and it has an extremely high heat-holding capacity. The heat-holding capacity of steam is much greater than that of water. Steam heating systems often operate at very low pressures and usually under 220°F. Steam heat is usually distributed by either one or two pipe systems. In a case of a one-pipe steam heating system, a single main serves the dual purpose of supplying steam to the heat exchanger and allowing condensate to run back from the radiators also. A two-pipe system has two connections from each heat exchanger or radiator. In this system, steam and condensate flow in separate piping from each other. With a steam system all pipes must be well insulated and you must use pipe insulation rated for steam piping. If the insulation is removed the system will no longer work as designed. Noise and all sorts of problems will come from uninsulated piping.
When you have radiators on upper floors or radiators that are further from the boiler they should be adjusted to release more air to compensate for the increased air volume in the piping due to the distance from the boiler. If you have a valve that is clogged with mineral deposits or stuck shut, no air will be able to get out of the piping. Because of this no steam can enter the radiator, so it doesn't heat up. This will block the movement of steam into the radiator, or cause a very noisy hammering as pressurized steam tries to get through this water "dam".
Steam radiators need to have a valve that allows air to escape at a controlled rate so that the radiator can heat up. Steam heating systems will also lose a little bit of water all the time, so there has to be water makeup so that you do not run your boiler dry. Steam heating systems without an automatic water feeder are not safe. You will risk serious boiler damage should boiler water be lost. If the boiler runs dry it could also explode if water is placed into it while it is hot. There should always be a low water cutoff installed on every steam system. Therefore on a steam boiler the automatic water feeder serves as a safety device also.
It is very important that you find someone that is very familiar with steam heating systems when repairing or installing steam heating. Incorrectly designed, installed, steam systems and condensate piping is a huge problem in today's buildings and facilities. There are not many qualified to design and install properly operating steam heating systems. Incorrect steam piping will always cause costly premature failure of steam equipment such as steam coils, heat exchangers, and control valves. Not to mention the higher cost of operating a system that is not working efficiently.
http://www.fixya.com/support/r3904286-steam_system_steam_radiator_air
http://www.fixya.com/support/r4008078-differences_between_steam_hot_water
on Dec 29, 2009 | Heating & Cooling
Does the boiler thermostat control the heat of the radiators as well as the hot water temperature? Does the thermostat control the water temperature and the pump - as our pump seems to be on all the...
There should be a control called an aquastat that regulates the temperature of the boiler. The thermostat will turn on the circulator to start the flow of water through the radiators. If the water coming back from the radiators is very cold, a control will shut off the circulator until the boiler can come up to a predetermined temperature then start the flow of water again. If you have a tankless coil for domestic hot water, you now have a triple aquastat that maintains the temperature for domestic as well as the boiler temp. So yes the boiler thermostat (aquastat) does control the heat of the radiators and domestic hot water. No the pump is regulated by your house thermostat. You should take an amp draw on the boiler and componants to find out what is drawing more electricity than it should and popping your fuse.
Feb 19, 2011 | Heating & Cooling
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
RAds don't get hot anymore
rads not heating could be down to old system ie pipework etc and sludge building up. r there any cold spots on rads? when boiler turning off do u mean going to reset? if so could be over heat prob at boiler . there should be a pressure pipe coming from boiler going to outside if its a combi. if this is leaking your expansion vessel might need re charged as this is where the water will be going.
Feb 05, 2009 | Combi Centre DX - Mango
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Ariston combi boiler
sounds like your diverter valve is passing on the boiler, this diverts the heat either to the rads or to the taps, if its passing through the heating chanel it'll heat up the rads- may also be a scaled up secondary heat exchanger, hope this helps you
Aug 21, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
