Question about Toshiba 51H83 51" Rear Projection HDTV-Ready Television
Scrambled picture. takes 30 min to warm up. - Toshiba 51H83 51" Rear Projection HDTV-Ready Television
    Brigadier General:
  • 8,909 Answers
I would hazzard a guess that there is an issue with old capacitors in the power supply as when they warm up the values return to near normal.
Check and change electrolytic capacitors in the power supply section.
Hope that helps.
Posted on Jan 03, 2011
Partial picture frozen
Hi Robert
Possibly bad video memory.
LSI Chip failure until warms up.
Feb 24, 2014 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
Soyo DYLM1988 vertical hold/jittering picture problems when starting up. Clears when warmed up & playing with monitor settings helps.
How old is the screen? if more than 5 years, the circuitry can go bad. I had this with one of mine, it would jitter for about 10 mins before it warmed up. Just get a new one, they are cheap as chips
Sep 27, 2017 | Soyo DYLM1988 Monitor
My tv when it turns on there is no color and after a while the colors appears, also the picture is distorded, any sugestions?
Its a older set and I have fixed and even owned one---bad solder connections and or convergence problems---can you describe better what it looks like when cold?
Nov 04, 2012 | Televison & Video
My TV pictures scrambles after warming up
Check and replace all the electrolytic capacitors.
Aug 28, 2012 | Televison & Video
HD channel picture is clear, but regular digital picture scramble
o.k. check all your connections
if you have a newer house check to see if you have a main hub in a closet somewhere and check all connections. Check your hd receiver and you may be able to chage the DPI the receiver receives in.
I have this problem on some of my non HD channels, also. So much for going digital. I get fuzz and pixel problems "from time to time", but, if it is really bad and consistent your should call your service provider.
Things to ask also ? are you using cable or satellite.
If satellite T.V. there are other reasons you could be experiencing problems.
hope this helps!
Mar 26, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
Picture is scrambled until it warms up. Can play DVD without any issues, but all other video inputs are scrambled for 30 - 40 minutes.
unit has a bad hyper module,NLA thru toshiba.try contacting tristate module or pts to see if they still rebuild them.toshiba part-23786198,MVPU13,PD0264A
you mite have to search to web a bit to find one if they dont rebuild them anymore.
Sep 29, 2009 | Toshiba 42H81 42" Rear Projection...
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
1/3 of picture becomes partially scrambled
sounds like you have a frame fold-over fault, does banging the tv have any effect (slightly bang the set on the sides), if it does then its more than likely a dry joint, check all around the frame output chip, hope this is of some help to you
Jun 02, 2007 | Sony KV-35S26 35" TV
Scrambling for first 15 mins
That is the exact problem I am currently having with my toshiba 50 in. I did some reading and it sounds like there is a temperature drift across one of the capacitors on the board and it takes longer and longer to warm up. Havent fixed it yet...
Mar 18, 2007 | Toshiba TP50H50 50" Rear Projection...
Toshiba 51H83 51" Rear Projection HDTV-Ready Television Logo
177 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
