Question about Samsung HT-C6730W Theater System
I just got an HT-C6730 home theater system. The blue ray would not play any DVD discs. I have the same probleme with an older Sumsung blue ray the BD-P3600. I'm thinking to bring back all my Sumsung products because I see they all have this problem. Does anyone kow how to fix this?
SOURCE: NEED TO UPGRADE MY HT-BD2 SYSTEM
There are two ways to approach this. You can either download the update from Samsung's support page, burn it onto a CD, place the CD into your Blu-Ray player and let the update load...or you can connect your Blu-Ray player to the internet and let the player download and install the update automatically.
For the first approach, the upgrade file can be downloaded by clicking on the following link:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=2149020&CDCttType=FM&ModelType=N&ModelName=HT-BD2&VPath=FM/200903/20090318095607437/081227_01_HT_BD2_XAA.zip
...and the instructions to installing the file on your system can be found here:
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=us&CttFileID=2149021&CDCttType=FM&ModelType=C&ModelName=HT-BD2&VPath=FM/200901/20090109105847140/HT-BD2_System_Upgrade_by_CD_Method.pdf
The second approach is detailed in the HT-BD2 User's Manual (pages 46-49). It requires you to first plug a network cable into the back of your Blu-Ray home theater unit, then connect the other end into a LAN connection on your wall (or into the back of your cable/DSL modem) Page 26 of the user's manual shows you how to make the connection.
Posted on Jun 19, 2009
  • 4 Answers
SOURCE: Soundproblems on my Home Theater System
http://downloadcenter.samsung.com/content/UM/200702/20070207171859140_XQ100TXQ100_GB.pdf
Suggest you go back and check all connections with speakers that wires are connected with input properly I have given you web address for manual usually find wires are not bared back enough for connection test each one individually with a tester to make sure there are no broken wires.
Posted on Mar 05, 2010
SOURCE: Need Vizio TV code for my Samsung HT-X50 home theater remote!
Mine is 5. Press the TV button and let it go. When it quits glowing press the power button and hold it down. Then press a number (1-86) on the keypad while holding the power button down. If the TV turns off, you are done. Press the power button again and the tv should come on. If it does not work. Release the power button for a second and then repeat with a different number until the tv turns off.
Posted on Jul 24, 2010
SOURCE: Have new Samsung 3D Blu Ray Home Theatre system
If you've find an answer to this, would you please post it here?
Posted on Jul 23, 2011
dunnbiker
  • 8546 Answers
SOURCE: I'm Tryin to connect a samsung blu-ray
Find the manuals and refer to them.
My personal spin on the instructions:
NO signal ever benefits from multiple connections or 'hops' and it gets expensive zig-zagging a signal all over the room. K-I-S-S is the word of the day. Run the BEST version of any signal directly from its source to the BEST electronics that will present it to you for consumption. The separation of audio and video inputs and outputs on a device is what allows and ENCOURAGES the direction of each signal to the BEST electronics that can process it. Example: your TV does not have the best speakers in the room so why send it any high-end audio?
Posted on Aug 21, 2011
No blue ray
If I remeber correctly, the Samsung HT-Z310 is a dvd system.....not blu-ray. Won't play blu-rays - never has, never will.
Jan 01, 2014 | Samsung HT-Z310T Theater System
How to play blue ray dvd on the LG HT554
Unless it is specified as being able to play Blu-Ray discs, it cannot do so, and there are no 'hacks' to enable this function as the HT 554 is a DVD player/home theatre system. You would require a Blu-Ray player to play both types of disc.
Apr 05, 2011 | LG Electronic LRA516 DVD Recorder
How do i connect my blue ray Samsung ht-bt1220 2.1 to play through my sky hd box
Connect an optical lead from the sky hd box to the Samsung Blue Ray.
Then change the function button on the Blue Ray to Din 1.
Then change settings on Sky HD box to Dolby and this worked.
Jan 16, 2010 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
I have a sumsung dvd home cinema system ht.thx25 when I put a dvd in it says disc unknown but when I put a free dvd in from the newspaper it plays.
Is the disc just a regular disc, not HD or blu ray?
Is the disc a region 1 coded disc?
If it is, the unit should play it fine.
Jul 01, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Disk stuck in my Blue Ray
Hi!
I had the same problem, and I solved it by shutting down the unit and then disconnected the power supply for some sec. When re-connecting the power supply and pushing the start button the DVD was ejected when pushed the eject button.
Egil
Dec 30, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Blu-Ray disc stops playing after 20 minutes
New Blu Ray home theater player can not play new Blu Ray movies according to Samsung customer support. It is a JAVA code issue and they are working on a software upgrade. No release date is known. I tried playing The Hulk, Ironman and Wanted. None would play.
Thanks Samnsung for wasting my time and money!!!
Dec 07, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Won't play blue ray discs
Your unit was built before there was Blue Ray discs. The DVD is not a Blue Ray DVD player
Apr 17, 2008 | Audiovox VD1400HT System
Samsung HT-C6730W Theater System Logo
29 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
