Question about Xerox Phaser 8400 Laser Printer
Color issue We have recently moved a Phaser 8400 into our dept. When we print the colors are not coming out like they should. My Calendar is blue and it printed in green. My boss printed out his sign in sheet which has a red banner and it came out almost brown. We have more than enough ink so thats not the problem and we have also tried updating the drivers. I have also tried running the cleanup utility and used a cleaning kit. Do you have any suggestions?
    President:
  • 2,072 Answers
If you moved it when it was warm, most likely you have spilled ink into the print head.
If it was shut down for more than an hour before moving it. There is a Tek Color correction you and run. You may have to go to the Xerox.com website and download it and run it.
I would also suggest updating the print driver.
But my guess is moving it damaged the print head and it will most likely need to be replaced.
Also if you go into the print driver properties, you can adjust each color intensity and saturation, you may be able to correct it in that way.
But from experience, I really suspect a faulty print head.
Posted on Jul 10, 2008
Xerox Phaser 6180N Laser Printer printing a faint but noticable blue line when printing in color - not an intentionalline. The lines are 3
Most likely replacing the cyan print cartridge will clear this right up. The part number is 113R00719 for the standard capacity. Iteminc.com has this in stock and ships same day for $99. Good luck, and thanks for using fixya!
Nov 21, 2011 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 8560 - I have been having print quality issues for a few weeks - what shows as bright blue on my screen or if I am printing a photo comes out very dark blue, purple comes out navy blue. I have...
Since it's a brand new printer it's probably not the printer, but your set up . Not knowing what program you are printing from, I can't advise beyond that 1) check the reference for the program you are printing from about setting up your color to be compatible with your printer (look under color management). Usually it has to do with your file's color profile matching the printer profile.
Oct 18, 2009 | Xerox Phaser 8560DN Laser Printer
Phaser 8400 print management
Yes you can. If it is just you printing you can go into printing preference. Then TekColor and click the black and white option. It will force everything printed to be B&W. You can only limit others to B&W if it is hooked up via ethernet with a IP address. Type in the IP address in your internet explorer as you would a webpage. Go to the properties tab then Printing Security Settings and type in a Color Permission pin. Then if you need to give someone access to printing color in the printers preferences on the layout tab click the advanced button, Under printer features there is a color access area that you can type in the pin to print color. If one color runs out it will not continue to print. It can cause very expensive damage to your printer if it trys to print with no ink in the printhead. So to be safe it stops the machine from printing.
Hope this helps.
Nov 21, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8200
That normally indicated a heating issue with the print head. Could be the printhead itself or an issue with the electronics module providing the source voltage for that heater
Mar 12, 2008 | Xerox Phaser 8200 Laser Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 8400
There is a flag sensor on the registration assembly that is possibly broken.
Sep 07, 2007 | Xerox Phaser 8500/DN Printer
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: http://www.phasersmart.com/ They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: http://www.office.xerox.com/printers/color-printers/phaser-8400/sprt-enus.html Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Aug 21, 2007 | Xerox Phaser 8400 Laser Printer
Phaser 8200
Not a problem, but turning it off causes the machine to do a setup, which then purges the ink supply and is very wastful.
Mar 21, 2007 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
305 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
