Question about Bosch Dishwashers
I have a BOSCH dishwasher moded SHU66C06uc/14. With the dishwasher turned on the water just trickles into the tub. There does not seem to be enough force in order to propel the spray jets. I have checked the water supply and do not have any kinks or blockage.
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
  • 249 Answers
SOURCE: BOSCH DISHWASHER Loss of power
check fuse in plug top,if its not that it could be door switch 30 years repairing. Close Ire....
Posted on Feb 23, 2008
SOURCE: bosch shv55mo3gb
use this link then click on insruction manual download type in the model number remember 0 is a number.I know that sounds condesending but i forgot. I used the manual with the ending aus.
http://www.bshappliancecare.com/Bosch/Bosch_dishwasher_manual.html
Posted on Jul 01, 2008
  • 161 Answers
SOURCE: Bosh dishwasher shu3322uc/22
check for leaks where the the top rack plugs into the rear. it might not be sealing. If your unit has the ability to change the top rack height check in the other position and see if it works. In my Samsung (Bosch in disguise) model The tube to the top rack plugs into one of two holes in the rear, depending which rack position I use. Something covers the hole not in use. Bosch uses two seperate pumps for washing and draining. So I don't think the pump could go partially bad. (This happens in other brands when the solenoid gets stuck between pump out and recirculate)
Posted on Jul 03, 2008
  • 412 Answers
SOURCE: Lower spray arm does not spin on my bosch dishwasher
Sounds like you may have put it together wrong. I would just take the arm back off and make sure that it all fits together right. A little tip for you too. Dishwashers will clog up all the time with water deposits and food gunk. There are all those expensive cleaners out on the market but the best and cheapest way to clean them is with white vinegar. Simply pour it into the dishwasher when it is empty and run it on the pots and pans setting on hot. Always make sure to pre heat your water too by running the sink till it starts steaming. This will make it easier for your dishwasher to heat the water. If you don't, then when you turn on the dishwasher it starts to fill with cold water and has to heat it on its own. Run the vinegar though through it at least once a month or so and it will extend the life of the dishwasher. Hope this helps. Just try taking that arm back off though and putting it back together making sure everything is fitting properly. If you have any other questions feel free to ask me. Good luck.
Posted on Mar 20, 2009
Have a Bosch SHU43C05UC/14 dishwasher. Water comes in, gets heated, but the unit never seems to go into wash cycle, fills, then drains a little.
This may sound odd but might work.
Reset the machine as to start a new cycle. Add 2-4 cups of water. If the machine starts and runs through a cycle then the water inlet valve needs to be replaced.
Good luck
Jan 02, 2014 | Bosch 24 in. SHU43 Built-in Dishwasher
There is a motor sound on my Bosch SHU66C05UC/14 dishwasher but it does nothing. The display seems ok and I have done the
Your dishwasher is in flood safe mode. There is water in the pan beneath the wash tub. Remove the lower access panel and dry all of the water out to restore operation, at which time you will need to address the leak.
Mar 02, 2012 | Dishwashers
Bosch Dishwasher - Model SHU43C07UC --- intermitently shuts off during wash cycle -- restarts later, sometimes several hours later and then finishes cyc'e
Cold water is the only type of water that fills your tub. The machine looks like it stops because it is waiting for the water heater to heat the water in your machine to a highert temperature, enough to get your dishes clean.On that model you can't say very often that your dishes don't get clean.
Feb 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU 43C06 UC17 dishwasher the dishwasher is just draining with no water in the tub, and is not filling, it does not seem to begoing out of drain mode
water in the bottomof the base remove side panel and dry out the bottom base . the float is up . thats why its in drain mode. bosch old tech speaking.
Oct 10, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water not filling in dishwasher
If I got your issue correct your Bosch Dishwasher does not fill enough water. There are some things to be done.
There is a Floater inside the tub protecting against overflow. when it is pushed up (by too much water) or stuck by debris, and does not fall down to its inactive position, it can prevent water from filling.
make sure there is no debris,and move the floater up and down until it falls down in its normal position.
PS : there is a floor cover underneath the door, it has a repair manual glued to it on the back. you can use "diagnostics" mode by pushing a specific sequence on the front panel, allowing you to go through each cycle in an accellerated way.
I am sure this would help you.
God Bless
Jul 09, 2009 | Bosch Dishwashers
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
White film on glasswear.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Nov 08, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher
My SHU9925UC/14 will not drain and leaks hot water from underneith.
Aug 30, 2008 | Bosch SHU9925UC Built-in Dishwasher
Dishwasher tub slowly fills with water after after completion
the internal parts of the valve are sticking open randomley.the diaphram/piston in the valve most likley have lime deposits on it due to poor water quality.you would need the water valve assembly but before you buy this part i would look where the water line goes into the dishwasher and it will lead you to the valve.remove the valve from the unit and disassemble the valve.clean all the internal parts in the valve and reinstall.75% of the time this works ,if not change the valve.
Jan 24, 2008 | Dishwashers
Dishwashers Logo
90 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
