Question about Bon Tool Co Gammon Reel Surveyors 12 ft
What is the weight of a 6 1/2' feet Gammon reel? Can I use it to work with a 3oz small Plumb Bob?
Bon Tool's 6 1/2' Gammon Reel weighs .10 pounds, and may be used with several sizes of Plumb Bobs, including a small 3 oz Plumb Bob.
Posted on Jan 03, 2011
How many feet in 8mm
no feet in 8mm
roughly 8mm is 1/3 of an inch or 3/8 "
Oct 23, 2017 | Video Cameras
What lb test fishing line does the 112 Oceancity fishing reel take ?
Is this the vintage 112 casting reel?.. You can use almost any size line that the reel will comfortably handle... too small and you might lose fish..and take miles of line to fill..... and .. too big and the reel will not function efficiently..its almost a judgement call.. use common sense..If you need a very small line.. you should use a "backer" to keep from using 1000's of feet of line to fill the spool..... and .. If you need a very heavy line... maybe a bigger reel is in the future... hope this helps..
Jul 22, 2017 | Fishing
My gammon joint is 1.194 kg in weight how long do I cook in the oven for
Based on a 1200 watt microwave. Increase time for less wattage devices.
Place in a large casserole dish with lid and cover with water.
Heat on High (full power) for 15 minutes then 15 to 20 minutes per 450g at Medium power.
Allow to stand before serving as always.
Feb 06, 2015 | In Microwave Ovens
What is the average weight for 5 foot 7 inches?
Female Ideal Weight - Above Average Height The average height of a woman in the US is 5-foot-4. When considering the weight and height ratio, a 5-foot-5 woman should weigh between 113 and 138, 5-foot-6 between 117 and 143 and 5-foot-7 between 122 and 149. The weight and height ratios continue to increase at approximately 4.5 pounds at the low end and 5.5 pounds at the high end of the range, per inch of height. A 6-foot-tall woman's ideal weight range is 144 to 176 pounds and a 7-foot-tall woman's range is 198 to 242 pounds. Male Ideal Weight -- Under 6 Feet Tall Men have an ideal weight range similar to that of women, but their weights are higher per inch. A man who is 5 feet 11 inches tall has an ideal weight range of 155 to 189 pounds, which is significantly higher than the 140- to 171-pound range for women. Men under 6 feet tall can determine their ideal weight without consulting a height-to-weight ratio table by starting at 5-foot-11 and a weight of 155 to 189 pounds. Simply subtract 5 to 6 pounds per inch from the low of 155 pounds, and 6 to 7 pounds per inch from the high of 189 pounds. Thus, a 5-foot-5 man has a range of 122 to 150 pounds and a 5-foot-tall man has an ideal weight range between 95 and 117 pounds. Are There Ideal Weight and Height Ratios LIVESTRONG COM
Jul 09, 2014 | Health & Beauty
How do you cast the reel so the spool dosent continue to unwind after the cast
On the side of the reel there is a knob that you adjust for the spooling.As a rule of thumb you adjust it so when you have a lure on,click the release button and let it spool out,it will only drop about 4 feet.Now! tighten it a fraction.Start casting and it will not go very far.Just before the lure hits the water,you put your thumb on the spool.Hard at first and then less as you get used to it.You can then adjust the spooling knob to go a bit further every time.You use your thumb on the spool to adjust the last 10 feet of line.Use a lure with no hooks on it to practise.It's called a plug.Hope this helps and you reel in the big one's
Sep 21, 2010 | Penn 320GT2 Graphite Levelwind...
Cant cast the pinnacle platinum plus lp 100 fishing reel more than 15 feet because the line tangles. Any suggestions?
Sounds like your drag is too loose. Best way to get used to setting a baitcaster, in my opinion, is to put a 1/2 ounce weight on the end of the line and engage the spool. The line should drop to the ground freely, but not full speed - if too fast, the spool will continue to spin and you'll get that dreaded birdsnest. If it doesn't reach the ground, you need to loosen it more. Once you have it set, keep that weight on and go practice, using the thumbing process Parorae noted in the previous answer.
They take some getting used to for sure!
Aug 04, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Plumb weight
No standard. Just use a scientific scale to determine weight. Your local druggist will have one.
Jan 09, 2009 | General Brass Plumb Bob
Heater pops the circuit breaker
Lakewood 5500 Heater - Here is a picture of the rear side of the open heater thermostat with the two switches for 600 and 990W at the left. The 3oz metal piece is the weight that broke off from the thermostat assembly. It fell down and made a short between the case and the power switch. There is a visible burn mark where the short occurred.
I am convinced that if the heater ever falls over, the metal weight will break off and fall down and probably create a short against the case. It may disconnect the 120V power at the thermostat or cause a high enough current to kick out your breaker in the house.
The attachment of the 3oz metal weight to the back of the thermostat is not strong enough to survive when the heater falls over; it wil break off.
Nov 13, 2008 | Lakewood (5500) Oil Filled Radiator Heater
Bon Tool Co Gammon Reel Surveyors 12 ft Logo
179 people viewed this question
Top Bon Tool Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Bon Tool Measuring Tool and Sensor Expert? Answer questions, earn points and help others
