Question about Microwave Ovens
BSEEMS TO HEAT THEN TRIPS MAINS AFTER ABOUT 1 HR
    Brigadier General:
  • 8,909 Answers
Could be a condensation problem making the mains leak to earth with the moisture.
See what happens if you let the door stay open after use.
Posted on Jan 03, 2011
  • Bernadette Reardon Jan 03, 2011
    MANY THANKS BUT PROBLEM IS WITH HOSTESS TROLLEY NOT MICROWAVE
  • specialistel Jan 03, 2011
    It was under the wrong description, no wonder the fault was rather strange!
    Hope you manage to fix it.
Hello I have a delonghi combi microwave and every time I switch it on at the mains it switches on for about a second and then trips the fuse in main fuse box
There is a short in the primary electrical circuit.
A microwave technician will need to open the housing to check.
The actual location of the fault can vary widely, ranging from water / moisture causing a short, wires burnt or touching, fan motor cooked, control board fault, a loose live connector floating, lamp holder fault, etc.
Jun 20, 2017 | DeLonghi Microwave Ovens
Hotpoint model 6671P convection microwave keeps tripping mains panel Fuse when start is pressed. Could this be a problem with a fuse in the Microwave or is is a dud magnatron? How best to test?
Too many watts on same circuit. Plug it into a different outlet and see what happens, not on same circuit. So one that stays live when micro trips circuit breaker.
Mar 05, 2015 | Hotpoint Microwave Ovens
Why does the mains. Fuse blows when door is opened
sounds like an earth fault it may not be the door itself, it could be you touching it?
Aug 18, 2014 | Daewoo Microwave Ovens
Trips electricity
I would check out your breaker at your box . See what amps it is rated and see what your microwave is . Also your micro wave should only be on 1 breaker with nothing else on it
Sep 23, 2012 | LG Microwave Ovens
Mains Tripping
we had that problem with my drier everytime i put it on it tripped everything in the house, we found out it was faulty wiring in the drier
May 24, 2012 | Microwave Ovens
When the turn on the Mains, display appears. We select Microwave option and power rating and time, and press Start, the Power to the Mains trips.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor. This will happen each time you try.
If it went dead a few or several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it's the transformer, this will happen each time you try.
The high voltage diode can also cause this symptom, but it will only happen once, not every time you try it.
I'd say you have a shorted high voltage capacitor.
Many microwaves have a technical sheet tucked away inside to help in locating and testing components.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/xformer.html
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Sep 05, 2010 | Microwave Ovens
Display blanks and unit stops working open door and re-enter on keypad cook time its start again sometimes trips and resets again Unit is old. Symptoms is like power fail except mains is fine?
It sounds to me as if the oven is overheating, another cause for this may me microwave leakage from the wave guide or finally a faulty control panel, either way the repair cost could be expensive so you may wish to consider a new oven.
Hope this helps
Jan 07, 2010 | Microwave Ovens
Blown fuse
Check your door switches or your turntable motor, these could also cause the fuse box to trip.
Mar 25, 2009 | Sharp Microwave Ovens
LG LRM2060ST trips circuit breaker sometimes
needs to have circuit of its own rated @ 20 amps powered by # 12-2-wg wire , also very good idea to plug into a good surge protector to protect its control board, as any computer the boards are very susceptible to spike voltage caused by lightning and power problems , as to how it worked before , breakers vary a little in the amount of current it takes to trip them with age , the number of time they have to be reset and heat they have been subjected to over a period of time so it is not unusual for say one 20 amp breaker to trip @ 16 and another @19 for example also the length of wire between the breaker and the appliance can effect the trip range
Jan 13, 2009 | LG Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
