Question about Compaq Evo D300 PC Desktop
Compaq evo D300-power outage in our building. turned this pc pn and fan begins to turn for 2 seconds and then stops. power stays on -cd rom opens but fan never starts, therefore can't log in. Help??
    Guru:
  • 1,833 Answers
According to your mail I can understand that your pc fan does'nt work properly.
# If It is your pc-processor fan then first check that the fan connected with motherboard
properly with power cable & don't get loose connection.
you can check that the fan blade don't get touch with any cable or etc.
Finaly you may check cpu fan control in bios settings, and set it on always on mode.
# If the fan is smps fan repair the smps or replace it.
# cabinet fan may not work properly for connection of power cable.
Check the electric line also of your house.
Posted on Jan 04, 2011
How to fix power switch
You motherboard has been shot so you need to unplug everything for an hour and then replug carefully. I hope after plugin your power switch will work.
For further more information or any clarification, contact me back.
Good Luck
Aug 14, 2012 | Compaq Evo D300 PC Desktop
How to replace compaq evo cd/dvd disk drive
hi.
open yr desktop cassing then u will see yr cd/dvd rom. then find for button to remove cd/dvd rom then pull tht tht boten and pull up yr cd rom.
new cd rom you must set jumper setting to slave then connect all cd rom cable. on yr system ten see yr cd rom will auto place in my computer.
regards
Feb 21, 2011 | Compaq Evo D510 PC Desktop
I tried to move my hard disk and cd/rom drive to a dell tower but did not work and now when i put them back in my compaq evo i am only getting 3 beeping sounds when i boot up then it turns its self off ...
Hearing more than ONE beep is "bad" news.
Check that the wires from the fan on top of the CPU are connected to the power-supply pins on the motherboard, so that the fan spins when power is supplied.
Check that the RAM is correctly seated in its slots.
Check that the video-card is correctly seated in its slot.
Disconnect the power-connectors from the disk-drive and from the CD-ROM drive, and then start your computer. If it still beeps, without these devices attached, then these devices are *NOT* the source of the problem.
If all else fails, take the computer to a qualified technician.
Jun 12, 2010 | Compaq Evo D500 PC Desktop
Compaq Evo D510 errors
the RAM may be corrupted or not properly installed into the slot. also check if the processor fan is working properly.
Nov 19, 2009 | Compaq Evo D510 PC Desktop
How can i boot from cd rom compaq evo n410c
HELLO THERE
If you go into bios and change the boot sequense to the cd rom first than the c drive than you should be able to just put the cd rom in the drive and turn off the computer and restart and when it turns back on it should say pressany key to boot from cd rom
and to be perfectly honest with you as long as this is a bootable cd rom you should just have to put in thecd rom and reboot the computer and it should come up just like i said earlier ok?
but if not do like i said and change the boot configuration so the computer boots from the cd rom first ok?
I hope that this has been very helpful for you
best regards mike
Nov 16, 2009 | Compaq Evo N410C Notebook
My compaq presario 900 won't turn on
1. Check if your battery is fully charge or if there is power in your Compaq Presario 900.
2. Check for defect in your power switch.
Sep 21, 2009 | Compaq Presario 900 /1500 Series EVO...
Compaq evo will not boot up
try to go to BIOS
if the pc is not allowing you to go BIOS then get a bootable cd & insert the same & boot the pc to the desktop & also open the chasis & reseat the memory sticks.
Apr 10, 2009 | Compaq Evo D310v PC Desktop
Boot pc problem
You can solve this by going into the bios setup & changing the boot order. Make the dvd/cd drive 1st in boot line then hdd. This should allow you to boot up from the windows xp disc. Hope this helps & please rate this solution fixya. Thanks.
Feb 04, 2009 | HP Compaq EVO D510 Intel Desktop PC -...
Compaq evo-d510-boot problem
What have you recently plugged in as new hardware ? this F1 response indicates that a piece of hardware is not properly configured to run , and F1 is the offered option to go to CMOS to complete the installation.A most likely item will be a USB powered piece of hardware.
Nov 27, 2008 | Compaq Evo D500 PC Desktop
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
Compaq Evo D300 PC Desktop Logo
41 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
