Question about Toshiba Satellite A135-S4527 Notebook
My toshiba laptop will no longer open up if i just shut the lid and come back later to work. I have to put it in hibernate for it to boot back up. also, last night, text would appear, but on most websites, no pictures.
    Brigadier General:
  • 8,909 Answers
Sounds like it is full of stuff it doesn't need anymore.
Run Defrag and Disk Clean regularly to keep it in tip top condition and make sure the antiviral programme is up to date as a virus can cause your problem.
Hope that helps.
Posted on Jan 03, 2011
Not waking from sleep
Don't be lazy, use the Shut Down command and then you will know your files have been closed properly and disconnecting the battery or power failure will not kill your data.
Apr 01, 2014 | Computers & Internet
Gateway NV52 won't wake up.
Is it clean? fan and vents? Unplug, remove battery, leave battery out, plug in, reboot. If that fails, Re Boot and try a System restore/recovery to a date before this issue. OR, Boot to Safe Mode, use this procedure to select Normal Boot: http://www.netsquirrel.com/msconfig/msconfig_win7.html When/If you get a Normal Boot, Open Control Panel, Power Options, select High Performance, select Change Plan settings, set plugged in both to Never, set advanced setting to your preference. Use this procedure: http://windows.about.com/od/customizingwindows/ss/set_power_options_all.htm Always shut down and unplug your laptop when not in use, remove battery when you use on AC, your Laptop/components will last longer, and will not be subject to possible power surge damage and the battery, IF it malfunctions will not cause a fire hazard.
Mar 01, 2013 | Gateway NV5214u Notebook
Dell e5420 close lid power problem
What is the problem? Open Control Panel, Power settings, Advanced power settings, set to High Preformance, Set Sleep and Hibernate to Never , Set Lid close to Shut Down, adjust setting to your preference, Always shut down your Laptop, unplug when not in use. Remove battery if you use on AC most of the time, your laptop will last longer and a boot everyday resets the computer.
Jan 11, 2013 | Dell Latitude E5420 Laptop Computer
Toshiba Laptop L650-12Q will not shut down
Windows needs to be shut down properly to keep it stable, if hibernate mode is being used it eventually corrupt windows causing all kinds of symptoms, I recommend you make a backup recovery disc, and disable the hibernate feature to prevent complete window failure.
May 07, 2012 | Toshiba Computers & Internet
When my computer goes into sleep mode it freezes after 5 seconds
There are a lot of systems out there having trouble with the sleep and hibernation programs in windows. The first thing I would do if I wanted to keep the sleep and hibernation programs in place would be to update the BIOS file on the system. I for one am a believe the computer in turning off the sleep and hibernation. They have caused more corrupt windows installations than I care to remember or work on again. If you want to try turning these off for a while and see how the computer reacts, go to the control panel > power option > scroll through the settings and change the way the computer sleeps and hibernates. Also change the setting for what happens when the lid is closed. Change it to "Do Nothing" this will correct a case of the computer not waking up from somply closing the lid. The lcd will automatically turn off when you close the lid and turn back on when you open it...you don't need the computer going to sleep simply because you close the lid for second.
Nov 08, 2009 | Toshiba Satellite A305-S6883 Notebook
Toshiba laptop stuck
try to use the restore cd.. .. select boot from the cd/dvd and boot the repair features with the OS
look at the boot screen that initially shows up and get in the setup.... switch the cd/dvd to be the boot device that starts first...
run the cd/dvd installation normally until you find a repair feature.....
then follow the standard repair method
Sep 30, 2009 | Computers & Internet
Toshiba A215-S4767 will not start up correctly.
First off, Windows just didn't like the way the computer shut off, I would just restart normally and see what happens. Next when it boots up and you get into windows, Go to the control panel > Power Options > go to the hibernation tab and make sure hibernation is unchecked. Next go the setting that reads "shutting the lid". You want to open this setting with a drop down list and pick "Do Nothing", this will keep the laptop from entering standby mode just for shutting the lid. Laptops do not like hibernation or standby modes....windows hates it and will give you all kinds of problems if you continue to use it.
Sep 27, 2009 | Toshiba Satellite A215-S4767 Notebook
Toshiba A135 random shut downs
chect the operating system maybe some files or configuration change.. try to re install the operating system,, save first you data or make back up.. in another drive.
Jul 06, 2009 | Toshiba Satellite A135 Notebook
Toshiba laptop won't wake up from stand by or hibernate
I had the same problem on my Toshiba Satellite U305, struggling with it for the past 4 months and having to use Shutdown each time I was done using it. Very frustrating! Toshiba worked with me several weeks, telling me to re-install Vista and all the fixes, which took a lot of work backing up etc and this did not fix the problem. Today they finaly told me to try entering this special command and it fixed my problem. Maybe it will fix yours too.
Create a shortcut on the desktop and to make the shortcut, right click on the desktop, choose Create Shortcut, enter CMD.EXE where it asks you to "Enter the location of the item". This will create an icon on the desktop that looks like a mini-command prompt. Then on the desktop, RIGHT click on the CMD.EXE shortcut/icon you have created and select "Run as administrator". This will open a command prompt window. Here in the black-box with white letter window, enter the command "powercfg -h on" (without the quotes). Reboot and see if the problem is resolved. This fixed my Toshiba Satellite that had this problem.
May 11, 2008 | Toshiba Satellite M100 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
