Question about Verbatim 500GB USB Desktop 500 GB Hard Drive
Hi, I have a Verbatim model #47501. Suddenly I can see on it only one folder, with the other 40GB not presented.
Verbatim 1tb
http://www.snapfiles.com/freeware/system/fwdisktools.html
HERE YOU FIND SOME HDD-TOOLS TO CHECK UP THE DRIVE WITH.
Jul 21, 2013 | Computers & Internet
How to download on verbatim flashdrive
Hi, if you want to download to the flashdrive, or external memory device you are able to "Browse" the location you would like to usually before downloading, like something from the internet. If you are trying to save pictures from your computer onto your USB flashdrive you can right click your picture, select copy then goto your start menu and select & open your USB drive, then right click and paste into the window or a folder that you have created. To create a folder on your USB, just right click into a blank space in your USB window when opened, and select NEW, then Folder =) Hope that helped
Feb 17, 2013 | Verbatim Electronics - Others
Pics gone in DCIM folder. Using a Nikon s3000 coolpix camera, connected to computer, F:\s3000 is detected, within it is DCIM folder present, and within DCIM folder presents Nikon100 and Nikon101 folders,...
You cannot create new folders on an SD card and copy images to them, as the camera will not recognise them, since they were not create in the camera. Copy the entire contents of the card to a folder on your HDD, then format the card in the camera.
Mar 18, 2017 | Nikon Coolpix S3000 Digital Camera
My verbatim 4 GB memory stick does not show folders, only files after cleaning it of virus
this might be because the virus contaminated the folders and had to be removed either to the virus vault or removed totally
hope this helps
Apr 13, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
I am having Verbatim 2.5 Portable Mobile Hard Drive USB 500GB and transfered my music mp3 file (with folders though my Windows7 laptop) into that. When I connect this with my Audio Theater Its showing some...
If some of the files came from music services like iTunes or a Windows Media store, they will be in formats other than MP3 and will not be visible on an MP3 playing device.
Are they surely all MP3 files?
Apr 11, 2011 | Verbatim 500GB USB Desktop 500 GB Hard...
I CANT DELETE FOLDERS IN MY HDD
Download a program called "Unlocker" and use that to see whether your folders are locked, and this will let you unlock them so you can delete them :)
http://download.cnet.com/Unlocker/3000-2248_4-10493998.html
Mar 08, 2011 | Verbatim 500GB USB Desktop 500 GB Hard...
Dumb me I forgot how to transfer data to my verbatim. Can you help.
All you have to do is open the window for the external drive and click and drag the folders that you want to copy. Always put files in folders or the drive will say it's full before it is.
Dec 09, 2010 | Verbatim External, USB 2.0, 750GB...
Is there a driver download for imac to get my verbatim reader & writer for compactflash to work?
Hi there.
There shouldn't be a driver required for your compactflash. It should be as simple as 'Plug and Play' (meaning: plug it in, and it should appear as an icon on your desktop).
However, to clarify this for you. Please supply the following information:
1. Name and Model of the Verbatim compact flash drive.
2. Is it New? IF so; Where did you buy it from? (IF New, you may need to have it replaced with another one.)
Sometimes Drives (whether USB or not) just fail. This can be for a variety of reasons.
One way you can check your disc drive is to use the Disk First Aid utility (now called : DISK Utility) which can be located in your Utilities folder.
1. Click on the Desktop.
2. Press Command-Shift-A (opens the Applications Folder).
3. Open the Utilities folder.
4. Open the Disk Utility application.
This utility will show you what disc drives are connected (in the left of the window) and from there you can choose to First Aid (Repair) the disc Drive etc...
I hope this helps. Let me know how you go. Please rate. Regards,
Feb 22, 2010 | Electronics - Others
My Verbatim suddenly stopped working on my Mac OS
It sounds like your hard drive is damaged. Hard drives are very, very dilicate pieces of machinary. The disk is paper thin and any sudden jarring, especially dropping it creates a warp in the drive. It could also be just a mechanical failure. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Jul 13, 2009 | Verbatim VER95327 USB Hard Drive
Verbatim 500GB USB Desktop 500 GB Hard Drive Logo
197 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
