Question about Dell 3010cn Laser Printer
Dell 3010cn error code 077 303 Close paper cover paper cover is open. Which is the paper cover and what can I do to get it going?
The Paper Cover is located on the top of the printer. It is the vented panel just behind where your printed documents come out. It lifts up to clear paper jams, and documents won't print until it is closed. Just push the panel down until it clicks in place...that should do it!
Posted on Jan 25, 2011
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
We have a Dell 3010cn printer laser and it has an error message saying "reseat fuser". We do not know what this means. Please help!
Hi
The "fuser" uses heat to melt the toner-ink onto the paper, to "fix" the ink to the paper.
Open the printer, remove the cartridge, and make sure that the fuser is _exactly_ "seated" into its socket. Replace the cartridge, and try againn.
Otherwise, take the printer to a qualified technician.
Jun 02, 2011 | Dell 3010cn Laser Printer
I have a Dell 3010 that has error msg paper jam fuser 077-104. I cannot find a paper jam anywhere in the printer. I turned it off, unplugged, checked under drum, opened all doors and checked everywhere....
you need to check the fuser, sometimes a small piece of papaer or a label stick on he fuser in order to do this you need to open the back and top cover. or take the printer to service
Aug 21, 2010 | Dell 3010cn Laser Printer
I get error message "Paper Jam Fuser 07-104" "Open Paper Cover Remove Paper" I have done that and cannot see any misfed paper. What is the proplem?
It could be a couple issues. The picker rollers may need to be replaced. There are sensors after the draw and after the fuser.
Sep 25, 2009 | Dell 3010cn Laser Printer
Error code 004-321 on dell 3010cn
This error means that your Drum Cartridge belt isn't aligned properly or the sensor for it has become dirty.
Open the top of the printer and look inside. There should be a blue tab on the right side to unlock the drum assembly. Unlock it and lift the assembly straight up to remove it from the printer.
Now, look at the thing you just pulled out -- the drum assembly -- and you should see a black rubber belt. If you turn the wheels that operate it, you'll see that the rubber belt is not centered, so the sensor can't see the little silver plate.
Pull gently on the rubber belt to re-center it, then reinsert the drum cartridge and close up the printer.
Jul 13, 2009 | Dell 3010cn Laser Printer
Error Code 077-300 close front cover
I would suggest, turning off the printer. Unplug the printer for about 3-5 mintues and hold the power button for a few seconds causing ALL power to disapate from the printer. Also known as power cycling. Please just insure the toner tray is properly inserted into the printer and close covers. Plug printer directly into the wall. Power it up and see if that helps your issue. If this helps you please rate my solution.
May 21, 2009 | Dell 3010cn Laser Printer
Problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Feb 10, 2009 | Dell 3110cn Laser Printer
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Dell 3010cn paper jam 075-134
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 12, 2008 | Dell 3010cn Laser Printer
Dell 3010cn Laser Printer Logo
465 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
