Question about Dryers
What year was kenmore dryer model #110.627.22101 and washer model#110.238.12100 made?
SOURCE: Kenmore Dryer Model 110
I found the solution to be very informative and helpful. However, I checked the resistance of the heater element and it is about 10 ohms, and is not open. The TCO resistance is about zero. What about the thermostat? No values were given to check it for, but I did check it's resistance and it was also close to zero. The thermostat sort or "rattles" when I shake it; is that normal?
I pulled the heater element out and looked at it, and can see no visible damage. Also checked the air outlet and hose - no blockage in the hose and the air output at the dryer seems fine.
What else could be causing the dryer to not heat. Have checked at all cycles and temperature settings (low, medium and high)?
Posted on Sep 16, 2008
  • 25 Answers
SOURCE: Kenmore washer dryer age?
Next to the serial number there should be a manufacter date. that is when it was made. I am guessing 2 years old.
But check on the back, it is peobaly printed on a small metal tag.
Most electronics have a manufacter date posted on them for warrenty sake. yours may still have a warrenty. you can also go to Kenmore website and in the search area type in the serial number and it can tell lots of info including if it is still under warrenty. wouldn't that be a nice surprise!
Posted on Jul 26, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore Elite dryer Model:110.C60952990 almost no heat.
Before assuming you may have a component failure, do a little routine inspection of the dryer and exhaust vent ducting.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be because the exhaust ventilation ducting is clogged. If you can't remember the last time the exhaust vent was cleaned, or if it has never been done, this can contribute to dryer performance problems. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat, causing poor drying results and eventual failure. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced.
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted with the moisture from your clothing. If the exhaust vent is kinked or has excessive bends that create choke points, lint will accumulate in these points. Once the lint starts to accumulate, the moisture from your clothes starts to collect in it, and more lint get trapped. This eventually creates a clog. The Rule of Thumb: The SHORTER and STRAIGHTER the exhaust ventilation ducting, the BETTER.
A simple test to determine if you have a clog somewhere is to remove the dryer hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the back of the dryer should be forceful and warm (about 140 degrees). If the air flow is normal and the clothes dry as they should, then you need to inspect the ducting thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs.
If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect.
If your exhaust vent runs to an attic, this is a poor design that gravity will always win because of the resistance the blower fan meets trying to push the exhaust up the wall. The lint will eventually collect in the ducting going up the wall and have to cleaned out from time to time.
Also, make sure you don't crush the dryer hose behind the dryer when you push it up against the wall. You should always leave plenty of space behind a dryer to prevent this from happening.
Rodents and birds are anotehr cause of dryer problems. If they have access to the outside exhaust vents, birds will build nests in them and mice love a warm place with plenty of bedding material (lint makes a nice nest). Make sure the exhaust vent is at least a foot from the ground and use a louver type cover to keep pests outside. Do not use a screen. It can resist air flow and clog.
In addition, you should be using semi-rigid metal type ducting that resists kinking, crushing and rodent infestation.
If the air flow is weak, then you need to inspect the dryer INTERIOR to see if the air blower is working properly and is not clogged. It is important to keep a dryer checked routinely. Failue to do so can lead to component failures and is a potential fire hazard.
If you have questions, please let me know. I hope this helps you.
Posted on Sep 18, 2009
Richie_asg1
  • 1036 Answers
SOURCE: kenmore stackable washer dryer model 5018000200.
If your service personnel have told you which part is defective - take it up with the manufacturers.
They may admit the fault - and offer you a replacement part - if you offer to pay the fitting.
This shows you are not after a full unit, and understand it is out of warranty period.
This is the way things are going now - with parts designed to fail after warranty period expires. - And manufacturers are making these parts part of expensive items - like main control boards.
This way - the customer ends up buying a whole new unit instead of repairing a 1$ component.
Posted on Mar 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Any known issues with the Kenmore Elite He4 Electric Dryer 11085089400?
Besides the thermal fuse, the thermistor, main control board, door locking system and the problems all over youtube and google, the dryer may last you about a year or so. That is if you only do laundry one a year. The HE4's are ****. Have both washer and dryer for about 5 years. I could now be a sears repair man with the amount of knowledge I had to digest while fixing these things. NEVER, NEVER again will I buy kenmore!
Sep 27, 2012 | Kenmore Elite HE4 Electric Dryer
The age is determined by the SERIAL number. If you post back with each appliance serial number, I can tell you what year they were manufactured. Include any letter designations that are in the serial number too.
Jul 23, 2009 | Kenmore 600 7965 Dryer
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
May 28, 2009 | Kenmore 43042 Front Load Washer
3.6cu ft.
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
How do I determine the age of a kenmore washer and dryer ,the model # for the washer is 110.20432990, and the dryers # is 110.60982990 , thanks could you please help
need serial # 1st letter is factory 2 is year next 2 numbers indicate week of that year ..letter e would be 1995 j was 2000 if i remember correctly 1 next letter in alphabet would be following year
Dec 22, 2008 | Dryers
Purchasing a stackable dryer that fits on Kenmore/Frigidaire 417.44102300 washer
there still models out there from sears that go on the same way as the old one trust me i know 4 a fact
Mar 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Dryers Logo
249 people viewed this question
Top Dryers Experts
