Question about GE Advantium SCA2001BSS Microwave Oven
FUSE BLOWN PART WB27X10388 - GE Advantium SCA2001BSS Microwave Oven
    Brigadier General:
  • 8,909 Answers
Http://www.appliancedepot.com/parts/parts-used/fuse-microwave-ge-wb27x10388-jvm2070sk02-jvm1871sh02.html
That is a supplier for you.
It is a semi surge sand filled ceramic fuse and the rating will be stamped on the end cap.
Hope that helps.
Posted on Jan 03, 2011
I have a microwave JVM3670SK06  ge what amp fuse does it use
I found a good site to find parts for the microwave. It has the fuse for $7. GE WB27X10388 Line Fuse PartSelect
Here is another search form different sellers.
WB27X0007 GE Microwave Ceramic Fuse Replacement
The fuse info
Specifications:
  • 250 Volt.
  • 15 Amp.
  • Type: Fast Blow.
  • Approx. 1.25"L.
Oct 18, 2015 | GE Microwave Ovens
Fix blown fuse on KGRA 806PSS oven
Check the fuse if it blown replace with new one
Sep 13, 2014 | Microwave Ovens
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
Sep 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My old GE Spacemaker II microwave (JEM21K001) died. I was using it, heard a little pop, and it lost all power. Is this something simple to fix like replacing a fuse or is it bulk trash at this point?
HELLO.
take on these steps to solve the problem.
Check if there is electric power on wall outlet.
If the microwave plug has fuse,check if it has not burnt.if these are okay there is need to take the last step.
things needed
1.Screwdriver
2.Ohmmeter
3.New fuse
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a JVM1850 1100 watts. It's not heating. Shortly after we got it I think a fuse blew because we always had to turn the vent on and then the cooking time which worked. Now, it stopped heating all...
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacturer and model. Parts are available at any of the following webistes: searspartsdirect.com pcappliancerepair.com appliancepartspros.com repairclinic.com The first three sites include illustrated parts listings that can help you locate and properly identify any parts you may need. If the model number you listed this question under is correct, the line fuse is connected in line with the power cord inside the unit and is listed as part of item 47 in the parts listing (part number WB27X10388). This microwave oven is also equipped with various thermostats that (if blown) can cause similar symptoms to that of a blown line fuse. So, if the line fuse is NOT blown, you may want to check all the thermostats to see if they are still good. You will need to remove each one and measure across the terminals with a multimeter. A good reading is 0 ohms. NOTE: The various thermostats are listed as items 27, 61, 74, and 77 in the parts illustration. The thermostats typically will trip if the oven cavity has been overheated. Cooking items that are high heat producers such as popcorn or baked potatoes in rapid succession can often cause this problem. Allowing the oven cavity to cool a few minutes with the door open between cooking can prevent this from occurring.
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Sep 08, 2010 | GE JVM1850 1000 Watts Microwave Oven
This is the 3rd time part number WB27X10388 needs to be replaced in our microwave. Where is it located and can I do it.
that is a fuse .. look for part number 101 in the following diagram
http://www.partselect.com/PartDetail.aspx?inventory=239525&SourceCode=3
click on the diagram to increase its size ..
you can do the work but make sure its unplugged while the case is apart .. there are potentially fatal voltage and current inside while plugged in .. look for swollen capacitors on the logic board .. (tops bulged up ) thay are normally round with flat tops .. china turned out about a billion of them that are defective.. they typically last a couple of years ..
Jul 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Where can I get a 20A 125v fuse for my emerson microwave from?
Most appliance parts places carry the fuse, and it's also available at Home Depot stores if you live near one. If you can't find the ceramic-body type MWO fuse, you can also use a glass type 3AG fuse of the same rating. They are the same size.
Mar 06, 2010 | Microwave Ovens
Microwave has no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytewyteyu
Aug 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to replace Thermostat or Thermal fuse
GE calls them TCOs or thermal cutouts.
There are three in this model and they can all be ordered here.
The reference numbers relate to the drawing here.
REF# PART# DESC
111 WB27X1127 TCO -BOTTOM
59 WB27X10195 TCO -CAVITY
104 WB27X10194 TCO - HOOD
101 WB27X10388 FUSE
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing. It usually shows relative component layout.
Aug 19, 2008 | Microwave Ovens
Open Questions:
See all GE Advantium SCA2001BSS Microwave Oven Questions
GE Advantium SCA2001BSS Microwave Oven Logo
479 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
