Question about HP PhotoSmart M627 Digital Camera
Camera hp m627
Hello, i have a problem with my camera hp m627, have an lens error m627-30. can you help me plz?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
3 Suggested Answers
SOURCE: camara hp m627
la camara cuando enciende dice error lens: m627-30 que significa eso y como puedo repararla
Posted on Jul 31, 2008
VOTIT
  • 2071 Answers
SOURCE: lens error m627-30
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras AV cable, and turn the camera on in picture review mode. Have no idea why this would work, except that quite a few people have reported some success with it.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
Hello my camera photosmart 627 displays this message at startup (lens error: M627-30) and will turn off soon. What should I do thank you in advance
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Nov 29, 2010 | HP PhotoSmart M627 Digital Camera
Hello, i have a problem with my camera hp m627, have an lens error 627-30. help me please!
When a lens error occurs, it is generally due to a 'binding' of the gear inside the camera which needs to be serviced by hp.com.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864899&tmp_track_link=ot_faqs/top_issues/en_us/c00864899/loc:3&lc=en&dlc=en&cc=us&product=1147860&lang=en
The above tells how to do a power reset, but if that doesn't work then try to have it serviced by hp.com.
Call 1-800-HP-INVENT
Aug 14, 2010 | HP PhotoSmart M627 Digital Camera
My photosmart M627 have error lens 30 Help me! Sul display della mia photosmart appare la scritta error lens m627-30 che posso fare grazie!!
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 07, 2010 | HP PhotoSmart M627 Digital Camera
Lens error m627-30.what can I do to fix this?the lens will not open.thanks,lynda
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Nov 04, 2009 | HP PhotoSmart M627 Digital Camera
Lens error m627-30 turnt on camera then the lens will not open screen displayed m627-30
Oct 11, 2009 | HP PhotoSmart M627 Digital Camera
I have a hp photosmart M627 camera. When I turn it on, the lens stays in and comes up on screen with a lens error:M627-31. Can you help please.
Jan 18, 2009 | HP PhotoSmart M627 Digital Camera
Lens error m627-30
Aug 25, 2008 | HP PhotoSmart M627 Digital Camera
Camara hp m627
Jul 09, 2008 | HP PhotoSmart M627 Digital Camera
Error code M627-31 WHAT'S THIS?
não sei o que aconteceu com minha câmera da HP, quando ligo aparece a seguinte mensagem?: Lens Error: M627-31
Mar 23, 2008 | HP PhotoSmart M627 Digital Camera
Open Questions:
See all HP PhotoSmart M627 Digital Camera Questions
HP PhotoSmart M627 Digital Camera Logo
99 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
