Question about Mr. Heater MH55FAV Open Flame Utility
I have a mr heater contractor series 75k, it fires like it should, runs for a very short period of time then quits running
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
I think your high limit switch is defective, and is kicking in. 21751 is the part number or just contact Mr Heater. http://www.mrheater.com/ContactUs.aspx
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 03, 2011
My mr. Heater contractor series 75,000 kerosene heater won't get hot the blower isn't kicking on its getting fire and it's got kerosene in it but it won't get hot the blower won't kick on?
Kerosene Torpedo Heater Repair + Test - YouTube
? 12:08
https://www.youtube.com/watch?v=k1nRieTELnk
May 25, 2013 - Uploaded by InductiveExperiments
I repair my "Reddy Heater" torpedo heater by installing a new ... I replaced spark plug, filters,photo cell, new K, it has fuel spray,spark but it won't ignite now! .... I removed my motor andhot wired it to an outlet and it worked fine. but when hooked up ....Mr. Heater 36,250 views ... Get video URL at current time.
Torpedo Kerosene Heater repair & HOW they work - YouTube
? 9:30
https://www.youtube.com/watch?v=ve0nzByP6SU
Dec 6, 2013 - Uploaded by sixtyfiveford
Could not find my manual and the Mr. Heater (75k),web site let me down for a pdf. Opening the .... Thanks for the video -- helped me get mine working again ... Fan runs also just won't fire Any help would be great Thanks.
Mr Heater Kerosene heater cleaning and maintanence ...
? 9:06
https://www.youtube.com/watch?v=2EzoWdZLExg
Jan 11, 2016 | Mr. Heater Heating & Cooling
I have 2 heaters that will run out of fuel when tank is still half full
What size LP tank are you using? If you are running (2) 175,000 btu heaters on a tank that is too small, especially in this cold weather, it will not have enough vaporization to keep up with demand. This will cause the outside of the tank to frost up and the pressure inside will be too low to run the heaters. You need more wet surface area, i.e. a bigger tank or just manifold 2 tanks together.
Feb 28, 2015 | Mr. Heater Heating & Cooling
I have a Mr. Heater 125,000 BTU contractor series shop heater and it started surging spurts of flame rather than run smoothly.
You may have contaminants in the fuel, such as water. Fuel that sits in gas cans can sometimes have condensed water in it. There may also be something that has clogged teh fuel flow.
Nov 26, 2014 | Mr. Heater MH125KT Utility
Water switch open , heater heats up for short period and cuts out
ensure pump is running at full prime. clean the filter out as well. disconnect both connections from pressure switch in raypack heater. check continuity. if switch opens at any point and you have no flow restrictions then replace the pressure switch
Mar 11, 2014 | Solar Rheem Gas Fired Pool & Spa Heater...
The nails will not drive into the oak flooring! the compressor is at 100psi and the nail gun mis fires or when it does fire it only drives the nail 1/4 inch into the flooring. It is a Akuzuki x-799
I am not familiar with that name of nailer but when I have run into that problem it was because of too much oil used in the gun. If so this will have to be cleaned out. You do not have to oil a gun every time it is used if not used consistantly for long periods of time. Also are you using the proper guage nails? Something to consider hope this helps.
Apr 25, 2011 | ProSeries Akuzuki Contractor Pro Series...
110,000 heater will run for 15 seconds,will not fire
The rotor in the pump assembly may have broken or cracked and is binding the rotation of the motor. The pump assembly can be removed to inspect, clean and replace any parts that are damaged. The manual will step you through this procedure and can be done in a short period of time. Your local hardware store may be the replacement parts on the shelve.
Mar 28, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
MHU45LP won't fire
The pressure switch to which you are referring is the switch connected to the suction side of your induced draft fan. This pressure switch will have a hose connected between the switch and the induced draft fan. Please let me know if you need any more assistance.
Feb 17, 2009 | Mr. Heater MHU45LP
Mr. Heater MH55FAV Open Flame Utility Logo
736 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
