Question about Toshiba Satellite Pro A200-EZ2204X Notebook
It powers is good. No disk activity e.g read ,when boot up. no display activity.
    Brigadier General:
  • 8,909 Answers
Boot problems
A200 series laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
When working download updated BIOS from Toshiba.com
Hope this fixes your problem.
Posted on Jan 03, 2011
2 Suggested Answers
bigc73542
  • 108 Answers
SOURCE: no boot or bios display
It sounds as if you might have a memory (ram) problem. You might try removing and reseating the memory just in case it has gotten loose or lost contact.
Posted on Jul 06, 2009
Power ok but no display
check cable - try with a known good one
Try with another monitor (it need not be CRT, can be LCD with the correct connector)
Next try a different graphics card (known good) in your PC, or switch back to on-board, integrated graphics. If it still doesn't work, suspect your motherboard.
I'm assuming you get the one beep from your system when you power up indicating it passed Power On Self Test, and hard disk activity from booting up. If not, the procedure will be different.
15.January.2015
Jan 15, 2015 | Dell M770 17 in.CRT Conventional Monitor
Laptop wont turn on, got green pwr and amb bat but will not fire up
Systems covered: All failing to boot without lighting up display.
Goal of this Solution: Try to determine whether system is (a) booting successfully while failing to light its display (indicating hardware failure in the display), or (b) failing to light the display due to failure to successfully transfer control to ROM BIOS (indicating a motherboard failure).
The fact that the Green power LED, and Amber Battery LED are lit seems to exonerate the laptop power supply (brick) circuitry. Even with a nearly dead battery, a Toshiba Satellite 1135-s1552 should work while plugged into a properly functioning brick.
Here's Toshiba support's (244 page) online PDF version of your laptop manual:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=434997&rpn=PS113U&modelFilter=1135-S1552&selCategory=2756709&selFamily=1073768663
If the HDD (hard disk) activity indicator LED is active after power-on, then your system has actually got past BIOS and is booting - your LCD monitor inverter circuit or Backlight may have burned out - and to use the system, you'll need to connect an external monitor to the RGB monitor port on the back of the system (see illustration on page 32 of User's Guide) to view system activity.
Alternatively, one may attach an analog TV, using the S-Video port on the back of the laptop (see illustration on page 32 of User's Guide).
Once an external monitor is working to display the ROM BIOS part of the boot sequence, you may find that the ROM BIOS is good enough to run a few BIOS-based diagnostics. Run them all - something may indicate the source of the boot failure. Ofttimes, enough of the motherboard remains good to provide interaction with the ROM BIOS, but some motherboard failure will subvert a full boot to Windows/Linux. An example of this type of failure would be a failure of the PCMCIA bus controller, which is vital for booting a disk-resident OS, but unaccessed (except by BIOS diags) when the user interacts with BIOS. Another common failure of this type is main memory (RAM) failure.
A working external monitor/TV also provides a chance to backup important laptop data to a flash drive, sky drive, or CD-RW discs.
If no HDD activity is seen after power-up, then either your BIOS is hosed (in which case you'll need a new motherboard), or another motherboard component is hosed (in which case you'll need a new motherboard).
You may want to transplant the HDD into a working PCMCIA-bus system (any laptop) to recover/backup your important data.
If someone recently attempted and failed to update the motherboard's ROM BIOS, then you know why the system is failing to boot and also failing to light the display.
Here's a link to a site with disassembly instructions for Toshiba laptops:
http://www.irisvista.com/
Most dead laptops (even those whose power supplies have been burned out by a nearby lightning strike with the system on 120 VAC power) will still have perfectly usable HDD module(s), and RAM memory cards, so that at the very least, these removable components may be recycled into memory reserves for your next laptop or sold (Ebay.com) to help defray the cost of a new system.
Dec 14, 2011 | Toshiba Satellite Computers & Internet
Cannot display anything when booting up. no disk activity read. screen blank
Its a black screen,is it?
Do you see a Blinking cursor?
Click the below link for a resolution.
http://support.microsoft.com/kb/314503
Hope this helps.
Cheers!!
Jan 03, 2011 | Toshiba Satellite Pro L300 Notebook
My acer aspire e500 has no hard disk aactivity
Try to discinnect CD/DVD driver also when you power on main cor dont instantly power on case, wait 5 minutes and then try. Such kid of failureas are causer by power adaptor system. Also try bios reset put off battery and wait 5 minutes to reset CMOS also power cord must be unpluged. Unplug and plug power sources to mainboard. then turn on.
Jul 30, 2009 | Computers & Internet
No boot or bios display, no disk activity, Boot from cd also fails. Only power on indicator.
Jul 06, 2009 | IBM ThinkPad T41 Notebook
Boot up problem
I thiknk your hard drive may have failed/corrupt. If so, a simple reformat will do. But if it has crashed, you will have to get a new hard disk. If you are really desperate about your data on your dead hard disk, go for a hard disk recovery activity. It may be costly though.
Jun 05, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Doesn't boot, lights on, no display
yip you are correct! your graphics card is fried. read this thread for more indepth reading...
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447626+1240509454187+28353475&threadId=1191277
please rate the solution you recieved
Apr 23, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Power On / No Boot
Is it POSTing? Do parts make noise and then theres a Beep? The beep means it finished the Power On Self Test. Once it posts then it will show splash screen or black screen with it testing hard drives disk drives etc.. If no post is the led lit that says A/C is connected? before you attempt to turn on? If no post and good ac to rear connector then you probably need a new motherboard.
James Mac
Aug 31, 2008 | Acer TravelMate 2300 Notebook
Dead compaq laptop, no boot activity
Larnold..Sounding like you need to check the LCD Power Inverter Circuit board.. this is located inside the screen a long rectangular circuit board that sends power to the screen backlight & Display Panel.. Could also be a Bad Backlight.. Try Booting it.. Hold it up to a light and look closely at the screen.. If you see a faint image but no light, it is the Backlight, if Just Black No Activity then its most likely the Power Inverter, OR a Bad Video Card.. You can test the VIDEO by Connecting the laptop to a Computer Monitor or similar with the laptops VGA Serial port.. then Use your function Key and Switch to 2nd Display.....(one of your F keys.. ).. If it Shows up on another screen, Its a Display problem and not the video card... Hope This Helps alittle.. Cheers
Jun 02, 2008 | HP Compaq Presario V6000T Notebook
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
98 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
