Question about Lexmark C543DN Laser Printer
What does firmware error mean - Lexmark C543DN Laser Printer
Error code b0605
Hi Ekera
Code bo605 Firmware error B0605 on HP LaserJet P2055dn (Printer Troubleshooting)Firmware error B0605 on HP LaserJet P2055dn A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. This error basically means the printer's firmware (controlling software) ...Download firmware from HP site & reload basic or updated firmware.
Cheers
Trevor
Jul 13, 2014 | HP Laserjet P2055dn Printer
What does this mean on my HP LaserJet P3005dn Printer, error 49.c02
This error is usually caused by out of date firmware. The printer is getting commands from a program like Acrobat it does not understand. Click thi slink to go to support page for your printer. Drivers Software Firmware for HP LaserJet P3005 Printer series Download the current firmware, I suggest the easy firmware update which is the first option, and then run that file.
May 20, 2014 | HP LaserJet P3005dn Printer
I am getting a 900 firmware error notice
A 900 Firmware error means that something has corrupted the code on your printer.
The easiest way to fix this is to go to www.lexmark.com > Support > Downloads and download the latest firmware for your printer.
May 27, 2011 | Lexmark X204n 4-in-1 Laser Printer
Thank you for contacting FixYa with your inquiry.
The HP4700 Printer The HP 4700 is a family of color LaserJet printers intended for use by work groups and small offices. The printer itself differs little from model to model with accessories including wireless printing options and various paper tray configurations.
Error Code 'Service Error 49.2' According to the user manual, 49.X error codes mean, "a critical firmware error has occurred." Firmware is Software that ties to specific hardware components. While occasionally this means hardwired programming, installed drivers often feed programming and instructions to modern devices.
Correcting the Error Firmware errors can often be corrected by turning the device off and on again. If this fails to correct the issue, reinstalling the driver software may correct the problem. If the problem persists, HP technical support should be contacted.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Dec 07, 2010 | HP LaserJet 4700 Printer
When I turn on my lexmark x204n it gives me a 900 firmware error how can I get rid of it and what does it mean?
Don
Mar 10, 2010 | Lexmark X204n 4-in-1 Laser Printer
KYOCERA FS2000D ERROR CODE F050 HOW DO I resert A MACHINE?
this is a firmware error... if you were installing firmware then your firmware became corruplted... either the media that you were using is bad which means by a new compac flash or if you are using a cable... the cable is bad... try different media and reinstalling firmware...
another possibility if you weren't downloading firmware is that you got hit by a powersurge and the rom on your main board is shot... this rom calls the firmware...
Nov 03, 2009 | Kyocera FS2000DN Laser Printer
I am getting error code F9. what does this mean?
f9 codes usually relate around the printer boards or firmware errors you could try uipdating the firmware of the sharp site or look at the printer board connections.. try unplugging machine from wall and then take the back panel off check the conections of the boards and reboot.
Jul 28, 2009 | Sharp AR-207 Copier
Firmware Upload Error Code: 7777
According to Sprint, If your phone already has the most current firmware installed it will generate this error code when you try to update it. Error code 7777 simply means there is no firmware update available. So no worries, you're good.
I got the same error and message on my LG LX370 when I tried to download the latest firmware on my new phone. I called Sprint and we tried just about everything before a supervisor confirmed that that was all the error code meant.
DK 12/04/2009
Jun 03, 2009 | LG Lotus Cell Phone
My Dell printer 2330dn is showing an error of 900.57 Firmware - what does this mean? It will not print
clogatto,
This error identifies a problem with the printers "internal language". Many times the firmware is just outdated and needs to be updated.
Since this firmware is vital in the communication of components, outdated firmware will cause miscommunication such as error messages or weird symptoms.
I would recomend having a tech update the firmware since you really need to know what you are doing.
Apr 17, 2009 | Dell Office Equipment & Supplies
LG error code 7777 on firmware upgrade
DK 12/04/2009
Jun 01, 2008 | Cell Phones
Lexmark C543DN Laser Printer Logo
307 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
