Question about Whirlpool Washing Machines
I have a 14 year old Whirlpool washer. Yesterday my wife was doing a load. She heard the machine had stopped so she went down to the basement to throw the clothes into the dryer. She smelled a strange odor, and the tub had not drained. I figure the pump must be gone. Should I have it fixed or should I just buy a new washing machine?
  • 731 Answers
Most washing machine pumps are mechanical and would leak if bad. I don't think the smell is from the pump... more likely the motor.
Probably best to put the repair money towards a new washer unless you do the work yourself.
Posted on Jan 03, 2011
Hello. I have a two years old Whirlpool washing
Unless you look underneath it will not be easy to confirm but please check the following.:
1. check if the motor has failed, the housing has come off.
2. checckif the belts have failed and brought it off the pulley.
3. check if the main spindle , pulley has come off from the main shaft.
4.check if theere is any foreign material struck in between the tub and outer cover. Checking with manually must confirm.
5. check aftert he above had been looked into to see if any other issues are visible or audible.
Hope these tips helps.
Aug 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Should we buy a cabrio?
Its recommended to buy whirlpool washing machine they are having the spares for their old model also when compared other brands
May 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Water is leaking from left rear side of Washer
that is the location of the vent and valves. suspect rubber hose from valve to dispenser is busted. remove top cover to see (2 or 3 torx screws on back) the older units had a bend in the hose that breaks.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Squeeking noise on whirlpool washer duet ghw9100lw2
replace your belt in back easy.every year if still has smell buy warranty your rear bearing is going bad."less soap plz"
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine woes
Buy a new machine. You have used it well. After Two repairs I suggest replacements
Since you are not paying for water I would suggest a top loader. I have been Happy with Kenmore (Whirlpool in Kenmore skin) or look at a Speed Queen Top loader.
Dont over load your new machine, learn what it can and cant handle.
Best of Luck T
May 28, 2008 | Whirlpool LSR7333 Top Load Washer
Water leaks out the bottom of door. metal ring with spring came off. put it back on and has leaked since
I have the same problem. I went to get laundry out of the machine and there is plastic piece with coded wires attached and metal tension that appears to go around the drum hanging loose. Probably have water but the machine is in the basement not too far from the drain. Mine is a duet 9100L about 4 years old
Oct 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
51 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
