Question about Rotary 4486 Dremel Chuck Quick Change Collet For
Chuch jammed wont move - Rotary 4486 Dremel Chuck Quick Change Collet For
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Hi
try with force to move it
if you can not move use a clamp
Posted on Jan 03, 2011
Jacobs 6A drill press chuch jammed. Can't adjust with chuck key
teeth on the internal spiral are broken or the spiral itself is cracked
junk it and get a new one
Jun 23, 2017 | Drills
Janome JF 1014 sewing machine, needle wont move, everything seems to be jammed. Manual wheel wont move.
can only guess that the timing is off. needle and bobbin case is jammed and you need to take it t a repair shop
Mar 04, 2017 | Sewing Machines
2010 sx4 stopped and red light and when light turned green, car wont move.when move gear to reverse, wont move either. Car is running just wont move
breaks jammed on .check the sliders to each brake .remove and clean them.and grease them .to stop them sticking.
Nov 24, 2013 | Cars & Trucks
2003 ford transit turbo manual gearbox, stuck in 2nd gear, cant start
does the clutch push normally or is the linkage broken not disengaging clutch, and then does shifter move around or locked and wont move, loose linkage in shifter or gears are jammed inside transmission and something went, if shifter wont move at all then trans is jammed inside and needs repair.
Jun 09, 2012 | Ford Transit Cars & Trucks
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
Just got the dp350 can not get the chuch to stay on no matter what i do
try this, get something like brake clean or equiv. spray the inside of the chuck and also the spindle, wipe clean with a paper towel. fully retract the jaws and using a block of wood tap on the chuck to seat it on the taper. You might have to move the table out of the way but it will work. If I have helped you with your request would you please rate this response accordingly. Thank you
Nov 05, 2009 | Delta DP350 Shopmaster 1/3 Horsepower 12...
Janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Feb 25, 2009 | Janome MyLock 634D Mechanical Sewing...
Balance wheel is totally jammed
machine was working fine when suddenly it just jammed up. Everything seems to be fine, but the balance wheel is completely jammed rigid. I've looked at the shuttle and there are no thread jams at all. The needle moves fine from side to side with different stitch selections, but wont go up and down with the wheel.
I have tried looking in the machine, but I can't find any thread jammed.
Apr 26, 2008 | Brother NX-400
Rotary 4486 Dremel Chuck Quick Change Collet For Logo
37 people viewed this question
Top Rotary Tools & Hardware - Others Experts
raysaw
ray gallant
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
