Question about Whirlpool Refrigerators
Refrigerant leak whirlpool model ED25DQ - Whirlpool Refrigerators
  • 958 Answers
If you have a refrigerant leak, you need a professional to repair it.
you can not do it yourself.
Posted on Jul 09, 2008
2 Suggested Answers
  • 236 Answers
SOURCE: whirlpool refrigerator leaks
the drain hole at the bottom rear is blocked. a pipe cleaner run down it should clear it out.
Posted on Apr 09, 2009
Whirlpool ed25dq Not Cooling
Unplug unit from the wall, remover the start relay from the compressor and shake it. If its solid possible bad compressor, if it sounds loose (broken part) then most likely bad relay. Verify your model number as you are missing some letters.
Good Luck
Dec 13, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ed25dq
It most likely is caused by a defective water control valve that continues to leak water into the ice make even while off. Your model uses a=> 2002182 Water Inlet Valve I am here should you have questions, Thanks Sea Breeze
Jun 10, 2013 | Refrigerators
FRIG NOT COOLING, NO FAN OR COMPRESSOR ED25DQ
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 30, 2011 | Whirlpool Refrigerators
Loud clanging when it stops running model # ED25DQ
When the motor inside the compressor stops, the internal springs absorb the momentum. If an internal spring breaks or (more likely) gets weak, it may allow the motor to bang against the outer case of the compressor. The refrigerator will most likely work many more years this way, but the only way to stop that noise would be to replace the compressor, which is cost prohibitive. If you can't live with the noise, buy a new energy efficeint refrigerator and recycle the old one or use it in the basement or give it away. PS. If you give nearly any refrigerator compressor, even a new unused one, a shake, you will hear it knock against it's outer case.
Apr 01, 2010 | Whirlpool Refrigerators
Whirlpool ed25dq icemaker not working even though
the water valve maybe the problem as it is a dual one,, and if filter moded it has 3 solnoides flow . that control water . ck sol with ohm meter or test cord . . ice maker also works only at 15 deg or lower . so ckk tempt of freezer .. mm
Jan 07, 2010 | Refrigerators
I have a Whirlpool Side-by-side Model # ED25DQ 25.2 My ice maker quit working. It is not letting the water come in. The arm is still rising and falling to let the ice out into the bin. What can I do to fix...
1) Check that the water filter is not plugged.
2) Listen if you hear the water solenoid energize as the fingers rotate around and come to a stop. If not, then you could have a bad water valve. If you do, check that something is not blocking the water flow through the valve.
The fill switch on the ice maker may be bad as well, which would prevent you hearing the water solenoid from energizing. It is located inside of the front cover of the ice maker.
Let me know what you find and I will help further.
Dec 12, 2009 | Kenmore 22.6 cu. ft. Side-By-Side...
ED25DQ refrigerator: will not stop running; find
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Oct 28, 2009 | Whirlpool ED2FHEXN Side by Side...
My water dispensor want work, I'm getting water, no humming when
Before you replace the switch have you checked the following.
Proper waterflow / pressure, filter condition, water line has no been crimped or bent, water line is not frozen.
Have you tried unplugging the unit and waiting a few minutes, plugging it back it and checking it?
I am sure these Q's may sound dumb, but I don't know everything you have already done. AND I hate to see people spend money on stuff they don't need.
Hope one of these help.
If so, please rate me.
Thanks,Matt
Sep 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED25DQ - not colling
Need you to look inside the fresh food compartment and turn the defrost timer clockwise slowly.
d01b0a9.png part number 6 is defrost timer. When you turn it and compressor stops leave it there for 20 minutes and see if the refrigerator comes back on. If not the timer will need to be replaced, Let me know, Sea Breeze
Mar 22, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Refrigerators Logo
338 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
