Question about Keurig B60 Coffee Maker
Sponge that surrounds the water spout that pierces the top of the k-cup is missing.. any suggestions?
  • 13 Answers
SOURCE: B100 splases coffee everywhere when dispensing
you have lost your upper needel gasket. it look like this an is color si orange. try to found It or call keurig to get new one cfebcf0.jpg
Posted on Jan 18, 2008
  • 60 Answers
SOURCE: I have had my Keurig B60 coffee maker for over a
Valve is not bad that is not the issue you need to contact keurig to help you Call Keurig 1800 Cup Brew
Posted on Mar 23, 2010
  • 60 Answers
SOURCE: part that holds the coffee cups that pierces both
yes the K cup holder! Keurig has a patent on that so you will not find it anywhere you will have to call them to get one 1800 cup brew
Posted on Mar 26, 2010
Testimonial: "thank you"
  • 67 Answers
i think you are talking about the black funnel part, the replacement k cup holder, i know of this great site that sells all kinds of replacement keurig parts i hope this helps http://stores.ilikenew.com/-strse-14/coffecoffee,-tea,-shakes,-diet,/Detail.bok
Posted on Jan 27, 2011
heatman101
  • 43501 Answers
SOURCE: The brewer heats up but
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
I have Keurig 2.0. I have been cleaning it. I put white Vinegar in and running it through the maker. I am now running just water, but the water is not running any better. Suggestions?
Did you clean the top of the Keurig. When the top goes down, it has like a needle point when may get clogged with coffee grounds. Get a paper click and make straight it object, I clean the paper clip the insert to point and clean out the excess coffee.
Jan 02, 2017 | Keurig Coffee Makers & Espresso Machines
Water and coffee leaks out of spout on second cup
it sound like you have some blokage why don't you give it a service ferst also check if the coffee is to fine it may cos this problem
Mar 12, 2016 | Breville Coffee Makers & Espresso Machines
Why does the water splash around the cup rather than stream out ?
Check the removable insert that pierces the K-Cups. It may be dirty from coffee residue and needs to be cleaned. The entire assembly turns and lifts out but be careful as the piercing needle is SHARP. After cleaning, try a new k cup and see if it works ok.
Sep 12, 2014 | Manufacturer KEURIG Brewer a: Mr. Coffee...
Why is my defrost cycle too long
I had the same problem it is not the defrosting I don't think your water tube is missing the cup for the water or it is almost missing it I will tell you what I had to do I removed my cup and spaced the clear water spout so it would just run derectly in the ace tray. It solved my problem. For me it was just common sense after it almost drove me crazy.
Jul 19, 2014 | GE GSH25JFR Side by Side Refrigerator
Verismo 580 leaks clear water in spout behind pod spout
Be sure you put the silver lever (embossed with the word Verismo) down before pressing the coffee button. (The small cup illustrated on the top right.
Mar 02, 2014 | Starbucks Single Serve Brewer, Verismo 580
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
Jan 20, 2014 | Nespresso Coffee Makers & Espresso...
I do not have a manual. How do I use this thing?
fill the water tank, plug it in, turn it on
open by handle in front, put in a pod, be careful NOT to touch the top there is a NEEDLE to pierce the pod, close it, put your cup under the spout, select cup size and wait. Just takes a minute.
You can also purchase a "my cup" which is a empty gray pod section that replaces the one with the needle and you can then use your own grounds making it cheaper to use.
Jan 11, 2011 | Keurig B60 Coffee Maker
Have cleaned the brew unit and the machine still does not work
If you are holding the brew unit in you hand look at the top you will notice a small knob with grooves, if you look to the bottom of that knob about 3-4 inches inside the unit you will see the screen. If it is no noticeable run water from the faucet over the brew unit.
Oct 06, 2009 | Saeco Odea Giro Plus Coffee Maker
Slow coffee stream and smaller brew size with B70
I had the same problem. In my case the needle that pierces the cup was clogged. All you need to do is unfold a paperclip (small and not plastic coated) and push it down through that needle to clear the blockage.
My unit works better then ever!
Dec 01, 2008 | Keurig B70 Coffee Maker
Keurig B60 Coffee Maker Logo
202 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
