Question about Cambridge Audio Azur 640A Amplifier
My CA Azur 640A v2 just cannot get out from standby because of protection circuit. the red light blinks showing that DC was measured at terminals, no matter if speaker cables are pluged in or not. In user's manual it's written if DC is detected protection shuts down the amplifier in the middle of operation - which is obviously not my situation. Even more strange is that sometimes (very rarelly) it starts normally and I can play music as loud as I want without any fault in sound. But next time again nothing.
  • 73 Answers
Most 640As suffer from this sensitive issue. It is not a fault, but a protection mechanism that is too sensitive. In some cases, it could be due to the open ground earth issue or Left & Neutral reversed at the wall plug. Check your wall plug's connection and if they are perfect, then it could be because of a electrical issue inside the amp. In that case, get the technical support from CA to fix this.
Posted on Mar 06, 2011
Cambridge audio 640a problem, olume goes to zero, I hear a little bang on speakers, light starts blinking!
This sounds like there's an overload in the main amp section. Often caused by a short-circuited device.
Oct 06, 2014 | Cambridge Audio Azur 640A Amplifier
Running four S70 Siroccos off the amp, everytime volume gets halfway the protection is cutting in with protection light flashing three times? When reducing down to two speakers amp cuts out three quarters...
You are overloading your amp. IMO 640A cannot handle heavy loads.
Better change the speaker combo and connect something that puts right load on the 640A. Else, get a meaty amp from CA.
Mar 04, 2011 | Cambridge Audio Azur 640A Amplifier
Red light flashes - will not work - could it be dust in the amp?
hi,
its not because of dust. AZUR 640A offers loudspeaker protection if the output of the amplifier goes to a high constant voltage (DC) because of some internal fault. This is a rare fault although detecting it could just save those expensive loudspeakers.
Due to the necessary sensitivity of the DC protection circuit, hard clipping of the amplifier may cause DC protection to be triggered. If this fault occurs switch the unit off, power up again and check
operation with a reduced volume level. If the DC fault occurs again contact your dealer for service.
ok
Dec 29, 2010 | Cambridge Audio Azur 640A Amplifier
Cambridge azur amp 640a working brill till yesterday !! now protection light !!!! turned it off numerous time etc plenty of venterlation carnt get it to work
Looks like the fuse blown.. or the classic symptom of electrical fault inside the amp. 640A uses a sensitive protection circuit often ends up in this irritating situation. Normally, there is nothing much you can do, but just check your wall plug connection for Open Ground or Left & Neutral reversed issues. If the wall plug is free of error, then you should better contact CA technical support.
Dec 08, 2010 | Cambridge Audio Azur 640A Amplifier
I have cambridge audio azur 640a amp. Problem I have is only the one speaker is working. Both speakers seem to be ok working off the left speaker terminal. Seems to be problem with output from right...
The fault is on the amp! It sounds like the protection circuit is detecting a surge on the channel and shuts it down to protect the speaker. I would check the semiconductor device(s) for the right channel on the heatsink of the amp. You might even see damage of burning on one!
Dec 29, 2009 | Cambridge Audio Azur 640A Amplifier
230 Voltage
Good Day sir, yes the 640a has a voltage selector switch.
http://www.cambridgeaudio.com/support_products.php?PID=105&Title=Support
Jul 21, 2009 | Cambridge Audio Azur 640A Amplifier
Problem with azur 640a amp
protection mode activated to protect your amp from a problem.
please disconnect all your speaker from the amp and check if it is fine start to connect your speaker one by one until you find the bad one which make the problem-change its cable first and then speaker itself.if the problem still you will have a problem in amp.
Jul 08, 2008 | Cambridge Audio Azur 640A Amplifier
Protection mode overuse
Flashing protection LED indicates there is problem with circuit. Have unit serviced
May 10, 2008 | Cambridge Audio Azur 640A Amplifier
No powering up
2 blinks is +B OCP protection. The manual states "Short circuit of power supply system in each circuit." and "Goes to the standby mode. Short circuit of +B line"
Dec 10, 2007 | Sony KP-53XBR200 53" Rear Projection...
TV won't turn on, red lights blinks twice.
The blinks can tell you the problem , is it 4 blinks that could be 3 different ics IC1509 Q1505 or IC502
Aug 06, 2007 | Sony KV-32FS13 TV
Cambridge Audio Azur 640A Amplifier Logo
853 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
