Question about Goodman GMS90703BXA Heater
My flame keeps going out. i can press the reset button and some times it will work for a week sometimes only 30 seconds. It is an intermittent igniter. The flame seems to "roll back" when it first kicks on. This only seems to happen when it is below 30 degrees outside.
    Novelist:
    Champion:
  • 230 Answers
Your GMS unit should not be intermittent ignition but direct electronic ignition. In any case the flame should never roll out of the chamber. There can be a few reasons for the roll out but sometimes a good cleaning of the heat exchanger and a combustion analysis can cure that. The intermittent flame issue is probably a dirty flame sensor and can be cleaned with light sand paper or steel wool. Be careful not to touch the igniter only the flame sensor. It is usually on the opposite side of the burners from the ignition source. Hope this helps :)
Posted on Jan 03, 2011
  • Troy
    Troy Jan 04, 2011
    call your local furnace installation company,
    tell them you need furnace tune up.
  • SNARKY1 Feb 03, 2011
    Changed alot of heat exchangers on Goodmans, so throwing in my 2c.
    One simple thing I look at is how the burners look BEFORE the main blower starts. Does it look like flame is being sucked pretty into heat exchanger? Now watch when blower starts. Does flame roll out then? Does flame in one or more sections start to look lazy?
    If so, you probably have a cracked heat exchanger. A Carbon Monoxide detector stuck in the plenum right above the furnace BEFORE the blower starts should detect this also.
    Also, find out pressure switch rating, and check actual negative pressure from inducer with magnehelic gauge. Sometimes, inducers are weak. Enough to keep press switch happy, but weak enough to let burners trip a rollout switch sometimes.
    Or sometimes impeller on Inducer will get hot and spin on shaft intermittantly. Try catching THAT in the act!!!
    Also yes, dirty flame sensors are one of my #1 service calls on Goodmans. Clean em every call!
    Hope that helps.
Service repair manual
There is sort of a universal reset for routers known as 30/30/30.
The trick to this fix is to KEEP HOLDING the reset button in the ENTIRE TIME. Do not release button until ALL steps are done.
Make sure the router is plugged in and ON. Press and hold the reset button in for 30 seconds. UNPLUG from wall (keep holding button in) and wait ANOTHER 30 seconds of hold time. PLUG BACK IN and continue to hold button in ANOTHER 30 seconds. Then release.
The link below is to an article I found on Google, you probably don't need it too, but is included for further clarity.
The 30 30 30 Hard Reset Rule for Routers
Feb 27, 2014 | Belkin Connect N150 Wireless N Router
Intermittent Start (expanded explanation)
Lint will jam the start/run switch on the motor. Vacuum out the motor real good and check that the switch moves freely, and all the wires to it are plugged in good.
Nov 30, 2013 | Maytag Dryers
Intermittent start
Not a thermo fuse sound like motor is struggling.
May just need taken apart and cleaned
I have a D-Link DIR 300 it was working fine last week however now i can not get conection. 1 Power light is on. 2. light next to power light (with tringle in it is onand flashing. 3. the light with the...
Sometimes routers can die periodically.
You can perform a 'reset' on the router to put it back to factory settings, but you will lose everything you have configured.
To reset, press(and hold) the reset button on the back of the router (its small).
Continue to hold it for 30 seconds
Unplug the power (while still holding the reset button).
Wait 30 seconds, then plug it in again.
(Don't let go of the reset button just yet)
Wait 30 seconds after plugging it in, then let go.
Go make a coffee or do something for 5 minutes while the router does its thing.
If all goes well you'll be back at square one.
Mar 29, 2013 | D-Link DIR-300 Wireless Router
I can"t keep my pilot light going.
I am assuming this is a patio heater. I have extensive experience with gas appliances. The most common problem with pilot light issues is the thermocouple it is a probe that is directly over the flame , it senses the flame and allows gas to flow, if it senses no flame the gas valve closes. Patio heaters are also quite finicky, sometimes a simple adjustment of the thermocouple will do the trick. Also thorough cleaning of the orifice is necessary at least 1 x a year.
Dec 12, 2011 | Pool & Spa
I have the Linksys Wireless-G WRT54GS Router and when i plug it into my modem, no lights come on, besides the power light which was already lit. I've tried resetting it (holding the reset button for 30...
There is another way to reset the router called hard reset..
you need to hold down the reset button for 45 seconds while its turned ON and don't let it go.
After first 15 seconds, take the power cable out but still keep holding down the reset.
After second 15 seconds, insert the power cable back in but still keep holding down reset.
After last 15 seconds, release reset and turn off the router for 30 seconds.
0-15 = Power ON, Reset button Pressed in
15-30= Power OFF, Reset still Pressed in
30-45= Power ON, Reset still Pressed in
If it still doesn't work then you got a bad router, can't be fixed. :-(
Feb 13, 2011 | Linksys Wireless-G WRT54G Router
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
Forgotten password on DG834GB router
For info if having problems you need to do a factory reset, just pushing a pin or whatever it is you use to poke the hole at the back of your router is just not good enough, here is the official line quote from netgear.
Full Reset;
Hold down the reset button on the back using a paper clip, for 30 seconds with the power on.
After 30 seconds, keep the reset pressed in but remove the power lead for 10 seconds.
Then plug the power back in and keep the reset down for another 30 seconds.
So in total the reset is down for 1 minute and 10 seconds
Log into the routers web based configuration page by, launching Internet Explorer and in the address bar type
192.168.0.1
username = admin
password = password
I was having problems with the 1.5 firmwire where the router was rebooting it's self 2-5 times a day, logs date and time changing back to default of 12:00 2002 or something near.
So far I have just gone back to 1.4.3 firmware which seems to work fine for a few weeks before requiring a power off and on.
Dec 18, 2008 | NetGear DG834 Router
My becket honeywell r7184p oil burner monitor is not resetting it keeps blinking a fast green. What should i be looking for?
my Beckett oil burner with a honeywell R7184P just did the same thing. Quit burning, blinks for half a second. The burner says press reset once, if it does not reset then call a local serviceman. It is cold here in Alaska, you betcha', and my oil must have jelled up. It happened once, but pressing reset solved my problem, two days later it stopped again. I applied heat (hair dryer) to my supply line, added an anti-jelling solution to my tank. Here is what I found.
"The Honeywell R7184P-1080 (interrupted control—transformer shuts down 10 seconds after flame is established) is now the standard control used on all Beckett oil burners along with the new “Cleancut” pump. The Honeywell control has both a 15 second pre-purge and a 15 second post purge feature, as well as internal self-checking of the control itself. The control has 15 second lockout timing plus a 10 second ignition carry over period. After 3 lockouts during the same call for heat, the control goes into restricted lockout., A restricted lockout condition may be reset by holding the reset button down for 30 seconds until the LED flashes twice. At any time the control is powered, the reset button may be held for 30 seconds to reset the lockout counter. There are several new “Service Features” with the R7184P control that make for easier servicing."
You have to press the reset button for thirty seconds. I don't know how cold it it there, or what number oil you guys are burning, but what I do know is that you guys have been pressing your reset button more than once.
This worked for me. Good luck.
Jun 12, 2008 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
428 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
