Rumbling noise sounds similar to a bearing problem
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Okay..Firstly check the Concrete Weights on top and bottom of tub assuming you have a FRONT loader, next is the motor secure/ check struts finally could be a bearing quite a big job...
Posted on Jan 03, 2011
My 54 plate xtrail has a rumbling noise but not exactly sure of the locin sounds more like front n/s gets worse 60-70mph
rumbling noises are an indication of wheel bearing problems
as noise travels it would be best to service all the wheel bearings
check the drive line cv or "U" joints as well
Dec 09, 2016 | Nissan XTrail Cars & Trucks
What might be experienced by transaxil/transmission bearings wear? Rumbling or vibrations?
Kia is bad with wheel bearings ;.About 80 to 100k they start going bad. You have to check them physically with a dial gauge or know how to inspect them in other manners. They cause a rumbling sound when they start to go bad.
Feb 01, 2015 | 2007 Kia Amanti Sedan
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
"rumble strip" noise
check the wheel bearings for condition and adjustment as it may be a failing bearing
Feb 14, 2014 | 1997 Toyota Land Cruiser
2004 ford freestar rumbling noise as I drive down the road at about 45-60mph - it sounds and feels a bit like I hit a rumble strip but it is coming from the engine
Sounds like a half shaft. Reach around behind each wheel and see if there is play in the shaft that leads from the wheel to the transmission. There should be no play. Other possibility is a bearing hub. Jack up car, grab the tire at 9 and 3 o'clock. Shake wheel if there is movement not from the tie rod then it is the bearing hub.
Jan 24, 2014 | Ford Freestar Cars & Trucks
Have a rumbling noise in left rear wheel while driving down the road 1999LexusRX all wheel drive.sounds like a wheel bearing.
Have the car put on a rack and have the noise listened to with a mechanics stethoscope to confirm the wheel bearing is at fault.
Sep 04, 2012 | Lexus RX 300 Cars & Trucks
During spin cycle washer is making loud noise
If it is making a sound like a loud rumbling sound similar to a jet plane taking off, it probally due to the seal has failed causing water to leak into the bearings. The bearings begin to rust, and no longer round and the noise gets progressively louder. It can be rather expensive to fix. Get a few estimates before deciding whether it is worth fixing.
Aug 30, 2010 | Maytag Neptune MAH6500A Front Load Washer
MayTag Neptune MDE6800AYW dryer drum making rumbling knocking noise
Have someone change the bearing, it sounds like it has busted on ya. The rumbling sounds like the ball bearings in the bearing have failed.
Jul 09, 2009 | Maytag Neptune MDE6800 Electric Dryer
2001 Sebring LXI convertable. Loud rumbling noise that increases as accelerating increases. Sounds like a rumble strip on the highway. I changed the tires with no change in the noise.
Bad hub bearing. Drive the car on a straght EMPTY road .@30 mph or when noise is audible, **** the wheel left than right (similar to a race car warming. tires) and listen if there is a change in the sound if so its a front bearing if not it should be a rear bearing .Jack the rear of the vehicle up and spin the tire holding onto the strut. Feel and listen for a vibration or noise. This should pinpoint that elusive noise.Let me know Good hunting
Apr 11, 2009 | 1998 Buick Park Avenue
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
