I Have an MPC 2000xl. Some of my soundpads are already non responsive, but I know that I should replace the pad sensors to rectify that problem. But lately some of my other control buttons are losing or lost function as well. My right cursor key has stopped working, my "C" bank button has to be pressed harder than the other bank buttons before it responds, and one of the function keys under the LCD screen is also responding only when pressed hard. Clearly these can't be fixed by replacing the sensor pads, so how can they be repaired? About how much will it cost if I either do it myself or take it to a repair shop?
  • 29 Answers
SOURCE: Key pad is frozen
is your phone been dropped or wet? check local service center near our place.
Posted on Sep 30, 2007
SOURCE: Marantz support question
Hi I had my SR7200 in the shop also. The 1st time they said that they couldn't find anything wrong with it. I brought it home and had the same problem. Brought it back and they had it for about 1 month and finally called and said that they talked with Marantz and the DSP needed to be replaced. They said that they would have to send it to Mararntz and it would cost about $150
Posted on Feb 28, 2008
Neoklassic1
  • 70 Answers
SOURCE: The menu button on my remote doesn't work
Try replacing batteries. If that doesnt work try aiming directly at Receiver's sensor. If all the other functions work except the menu see if you can access menu directly from the unit itself. If it works then you might need to replace the remote
Posted on Oct 13, 2008
SOURCE: "PROTECT"flashing, no response, STR-SE391
The audio amplifier IC are fried and need to be replaced
Posted on Feb 07, 2009
  • 686 Answers
SOURCE: Microwave Key Pad stopped working
buy a new one they are not expensive wal-mart has 1000w for about 80 bucks
Posted on Feb 20, 2009
My mpc 2000xl lcd screen is out part number is s-11114b but cant find any
For PSP-1000 (Phat) LCD Screen
For PSP-2000 (Slim) LCD Screen
For PSP-3000 (Slin&Lite) LCD Screen
I Ordered the one for the PSP-2000 (That's what I have) and it worked perfectly.
Nov 28, 2010 | Sony Sharp LCD Replacement Screen...
My mpc 2000xl is not recognizing the sound disk when i try to load what should i do?
try letting it sit for a few minutes. That worked most of the time with my xl
May 05, 2010 | Akai Mpc2500 Music Production Center
What sound files can be loaded from a pc to an mpc 500? aiff, wav,mpc...? thanks
Data Compatibility
MPC1000: SEQ, WAV, PGM
MPC2000/2000XL: SEQ, WAV, SND, PGM (Most parameters of PGM file can be loaded.)
MPC4000: SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
MPC3000: SND (THRU Computer)
Z4/Z8: SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
S5000/6000: WAV only (THRU Computer)
S1000/3000: No compatibility
Feb 21, 2010 | Music
I have a Mpc 2000xl. I also have a small fast track m-audio. My bx5a monitor speakers the grey and red wire is connected to that. There is a guitar symbol in the back of my fast track m-audio. So what i...
The jack with the guitar symbol is a high impedance input for a guitar so you will get a proper level and sound when plugging your guitar straight in. All of your question did not appear in the post so try rewording it so we know what you are trying to do. Thanks.
Jan 25, 2010 | Music
Power to the outlet, but apparently no power at the touch pad - it is non responsive with no indicator lights on.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
If all the above checks out OK, replace the touch pad.
May 30, 2009 | Kenmore 2205x Top Load Washer
Screen says waste ink near full
These are pads located directly below the cartridges while in it's resting position.These pads can be removed with tweezers and cleaned with any ink removing cleaner and then with warm water and soap,Dried and replaced.
Apr 05, 2009 | Canon Office Equipment & Supplies
Not reading my floppy disk( MPC 2000xl by akai)
Have you tried formatting the disc using your MPC 200XL?
Mar 20, 2009 | Music
I have a Akai MPC 2000xl and its frozen do you have FIX? tHANKS
yes, i think i can help you with that.you need a good boot disk,maybe the latest os system disk.
Nov 24, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
