Question about Arris Netopia - 3347-02 High-Performance Wireless DSL Gateway - 1 x WAN, 4 x LAN Router
Set up to use a Toshiba Strata IP phone.. - Arris Netopia - 3347-02 High-Performance Wireless DSL Gateway - 1 x WAN, 4 x LAN Router
We have a multi-line set up using Toshiba Strata DKT2020-SD phones. I would like to shut the ringer off on one of the phones, and am unable to locate a programming guide that specifically addresses this...
www.atsco.info/.../CTX%20DKT-IP%20Handset%20User%20Guide.pdf
Hi please find above your user manual. Also often, well, sometimes, on the side/rear of the phone, there is a small slide switch, that is used to control the ringer, or as related hopefully the manual will show you how.
Feb 14, 2011 | Toshiba DKT-2020 Corded Phone
Group Pickup setup on Strata 280 phone system
Try Googling (Toshiba)(280)(manual) without parens.
Aug 12, 2017 | Toshiba Computers & Internet
Multiple voicemail boxes for a single phone number
I would guess you have the Stratagy VM? and it would have to have the Admin program and Connecting cord to program via RS232 more on ths cam be found here
http://guides.idacomusa.com/
Sep 28, 2009 | Toshiba Strata PT-390 Corded Phone
Toshiba Strata DKT 3512 ,!how to set the speed dials!?
for strata CIX/CTX if the program r enable
#66 100 to 109 (speed dial code) 9 follow by destination number #
Mar 13, 2009 | Toshiba DKT 3010 Corded Phone
Toshiba strata dk 280
it may be setup to block outbound calling, remember also, you have to dial a 9 to get dial tone on a centrex line, so in this case if your phone system is setup to dial 9 as a line access code you will actually have to dial 99. hope that helps
May 13, 2008 | Toshiba Strata PT-390 Corded Phone
HOLD CALL PROBLEM
I assume you have a strata Dk or Strata CTX you need to call your local dealer unless you have the software program then I can help you.
Apr 16, 2008 | Toshiba DKT-2010 Corded Phone
Toshiba strata dk280
http://pdf.textfiles.com/manuals/TELECOM-S-Z/
Mar 26, 2008 | Lands Phones
Phone ringer has turned off following a power outage.
I am assuming you have a Strata VIe system with this phone. I added a website below with all the program manuals. If you have a DK system please look at program 81 to get ringing back. I dont know the programming very well on the Strata VIE systems.
http://www.wedophones.com/ToshibaManualsLead.htm
Dec 07, 2007 | Toshiba EKT6520SD Phone
Toshiba Strata DK280 Conference Phone
Are you talking about a special speakerphone that is not made by Toshiba? This would be a single line phone device not a proprietary Toshiba phone and you would need a special card in your system that can handle single line devices. You may already have one that has a free port on it.
However, it does sound like you would need to find help from a local phone system installation company. You cannot plug a single line phone into any phone port on your system. A special wire would need to be run just for that phone and the system would need to be re-programmed for that port. If you need a single line card it will be even more complicated.
Oct 08, 2007 | Panasonic KX-T7730 Corded Phone
Arris Netopia - 3347-02 High-Performance Wireless DSL Gateway - 1 x WAN, 4 x LAN Router Logo
57 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
